Help with steering
Old Mar 24, 2009 | 11:39 PM
76toy's Avatar
76toy
2nd Gear
Default Help with steering
I replaced all the front end suspension but while driving down a straight road if the car goes one direction and you try to correct it , it jumps and over steers the other direction. Gets scary to drive , no fun
Old Mar 25, 2009 | 01:25 AM
Peterbuilt's Avatar
Peterbuilt
Default That's not good!
Sounds like you need a proper alignment. I changed out and replaced everything in the front end except the original springs and replaced the rear bearings in the trailing arms and installed new rubber in the springs and front trailing arms, then I went to a few alignment shops untill I found a nechanic that owned a C-3, first question he asked was how old are the trailing arm shims, I told him they were brand new, he said the steering box was good and after the alignment he took me for an 80 mph test drive down the highway. That was 9 years ago, my 74 still tracks perfectly and had the alignment checked 2 years ago and it is still good to go. PG.
