TH 400 Torque Converter Stall Sped
Old Mar 26, 2009 | 10:41 PM
shelsands's Avatar
shelsands
Default TH 400 Torque Converter Stall Sped
I have a 1971 BB 365HP car that I am trying to figure out what the orignal stall speed was of the torque converter Mine hs been changed once so cannot use an numbers from it to figure it olut that way. ny help greatly appreciated.
Sheldon
Old Mar 27, 2009 | 10:43 PM
baxsom's Avatar
baxsom
i just had a 2500 installed this past week and the tranny shop said that since it was only a thousand more than stock i would be ok without using a cooler.
to find the speed of yours
just hold the brake and hit the gas
where it brakes loose and starts moving is the stall speed.
Old Mar 28, 2009 | 12:49 PM
7T1vette's Avatar
7T1vette
Somewhere around 2000 rpm..1800-2000 would be normal for a stock engine. Torque converter stall speed is rated based on the input torque applied to it, so if you have upgraded your engine at all, you'll need to call a converter manufacturer to tell them about your engine/HP/torque in order to get a good match. [i.e., an 1800 rpm stall unit for a 365 HP engine would stall about 2100 rpm if the engine were upgraded to 400 HP; the more HP applied, the higher the stall speed for a given converter]
To TH 400 Torque Converter Stall Sped
