Brake line help!!!
Old Mar 29, 2009 | 01:05 AM
cjriojas's Avatar
cjriojas
Default Brake line help!!!
i need the brake lines that run from the front calipers to the combination valve on a 1976. Is there a PN or some kit where i can just run the single line. i need both left and right. Thanks
Chris
Old Mar 29, 2009 | 05:22 AM
GOLDEN65CPE's Avatar
GOLDEN65CPE
Default Front Brake Lines
You can get pre-formed correct armored brake lines from In-Line Tubing out of Shelby Township, MI. (Armored is the spring wrap on the lines). You need one long crossover line that runs from the proportioning valve across the front of frame and terminates at the junction bracket on the right side. A second short line runs from the proportioning valve to the left side junction bracket (The junction bracket is the small bracket welded to the frame where you connect the metal lines to the flexible brake line hoses. If you P.M. me with your e-mail address I will send detailed pics of the lines and related clip attachments. I am in final stages of restoration of my 75 rolling chassis and have documented description and pictures of all stages of assembly. I hope to publish when complete. Anything you need, please let me know, AL
Old Mar 29, 2009 | 09:38 AM
SmokinBBC's Avatar
SmokinBBC
Wilcox has them.
http://willcoxcorvette.com/product_i...ducts_id=15600
Old Mar 29, 2009 | 06:27 PM
cjriojas's Avatar
cjriojas
Inline tubing is closed so i have to wait till tomorrow to call.
Thanks, exactly what i needed SmokinBBC. Is this the correct one for the left side:
http://willcoxcorvette.com/product_i...ducts_id=15599
Chris
Old Mar 29, 2009 | 06:52 PM
72LS1Vette's Avatar
72LS1Vette
Chris
Check with Willcox to be sure. The pic looks long to me, but sometimes the pics don't match the actual product. The left side line from the block to the flex hose is only ~4" long, at least it is on the 72. Later years moved the block if I remember right.
Rick B.
Old Mar 29, 2009 | 08:37 PM
GOLDEN65CPE
Default Brake Lines
Chris, P. M. me with your e-mail address and I'll send pics of the installed lines. AL
Old Mar 29, 2009 | 09:02 PM
cjriojas's Avatar
cjriojas
pm sent
Old Mar 29, 2009 | 09:06 PM
larryg3's Avatar
larryg3
get them at inline that is their specialty i just did mine on my 81. and the line fit perfectly
To Brake line help!!!
