Wiped Out Lobe Symptoms....
Old Mar 30, 2009 | 05:49 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Default Wiped Out Lobe Symptoms....
How can you tell your lobes are history? Does the engine really misses? Do you use oil? What are the symtoms?
Old Mar 30, 2009 | 06:26 PM
Gordonm's Avatar
Gordonm
Depends on how wiped out the lobe is. I have seen some cams with lobes that are pretty bad and it seems to run fine. Of course it was a mild cam to start with. Your power level will drop off and yes it will start to miss at a higher rpm. If you suspect anything pull the valve covers and measure the lift.
Old Mar 30, 2009 | 06:34 PM
Ganey's Avatar
Ganey
W/ soild lifters or anti-pump up hyd., you would hear the increased lash.
Old Mar 30, 2009 | 07:04 PM
Daffy2's Avatar
Daffy2
In my case (solid lifter 365 hp), a worn exhaust lobe resulted in pressure in the crankcase and some excess oil backing up into the aircleaner. This caused eventual fouling of plugs - but still ran strong.
Daffy2
Old Mar 30, 2009 | 07:18 PM
DRIVESHAFT's Avatar
DRIVESHAFT
It will miss. Another common problem if it is an exhaust lobe that is
worn is that you will get a steady popping back through the carb.
Old Mar 30, 2009 | 07:49 PM
vetteguy75's Avatar
vetteguy75
Daffy2
What if you have hydraulic lifters? What would be the symptoms?
Old Mar 31, 2009 | 03:23 PM
WillEE's Avatar
WillEE
I experienced a wiped lobe with Hyd. lifters (comp cam 268XE). First symptom was excess play in the valvetrain on this particular lifter which showed itself in the form of a ticking sound. Same sound as if you had a slightly loose rocker that needed adjusting. I verified was a wiped lobe by removing valve cover, remove spark plugs, turn engine slowly with wrench on crank and watch the valve train while looking for rockers that don't move as high as others.
To Wiped Out Lobe Symptoms....
