Installed a centerforce clutch on my '71 427 sb. Instruction sheet says: "All centerforce clutches require a break-in period of 450-500 miles of stop and go street driving before applying full engine power. This period is required to properly seat the disc with the pressure plate and flywheel."
I never heard of a break-in for a clutch before. Is this really necessary? That's going to take the whole summer with as much as it gets driven! Any experiences? Thanks.
When I installed the DF Ctr force clutch, I did not care about this.
But I also resurfaced the flywheel.
I found the grip of the clutch to be excellent right away.
Then again, I don't race the care, so don't do launches starting at 5000 RPM. But when I feel like stepping the gas, I do so regardles.
Don't worry too much. Try it and you will feel if it grips correctly.
I find you have to stay on top of the pedal "free play" adjustment for up to 3K miles before it settles down for the long term. If you don't keep the free play adjustment proper, the clutch will seem fine at low RPM but when the counterweights move the Bellville spring rearward at high RPMs you will unload and burn up the disc pretty quickly. You need 1-1.5" of freeplay in the linkage before the throw out bearing contacts the clutch fork to allow for the counterweight action of a CF clutch. Free play is easy to check, grab the linkage by the "Z" bar and watch the action of the linkage you want the clutch rod to have 1-1.5" of movement. I have also had to use a 1/2 heigth nut on the clutch linkage to allow for enough initial freeplay adjustment on one installation with a aftermarket bellhousing. The 1/2 heigth nut (a nylon locknut) was on the front side and I used 2 nuts at the rear to lock the clutch linkage adjustment. If they are broken in correctly CF clutches will live a long life.
Rgds. Günther
I resurfaced my flywheel too. I'll probably start jumpin' out on it then and see how she does. Thanks.
Are you saying that as the clutch breaks in, the freeplay will increase, so you have to adjust. If you don't, the clutch will start not releasing fully and burn/glaze?
Are you saying I shouldn't start dumping the clutch on hard launches?
Over the years I've broken a bunch of stuff on my poor old Vette. So a high rpm dump the clutch is not on my "smarter things to do" list Slipping the clutch with your foot on the gas is even worse
I usually just off idle let the clutch out fast and then ease into flooring it with slicks. I use my motor TQ to go. Your 427 should be the same. To take off fast takes practise because my tires want to spin from a dead stop.
Think long and hard about what is going on: as the disc wears, the pressure ring moves FORWARD towards the flywheel, as the ring moves forward, the bellville spring moves REARWARD thereby REDUCING clearance to the throw-out bearing. If you don't keep freeplay adjusted, the spring will bend backwards at high RPM and unload the clutch disc at the worst possible time. The 1-1.5" of freeplay is the movement of the clutch pedal not the rod, if you don't have 1-1.5 inches of freeplay with a CF clutch, you will have high RPM problems. My clutch pedal moves over 5" in travel maybe the other poster should remove his **** carpet from the 70's along with the velour upholstery and get something nicer in his Vette if he can't get 1-1.5" of free play in the clutch pedal.
[QUOTE=Solid LT1;1569535808]Think long and hard about what is going on: as the disc wears, the pressure ring moves FORWARD towards the flywheel, as the ring moves forward, the bellville spring moves REARWARD thereby REDUCING clearance to the throw-out bearing. If you don't keep freeplay adjusted, the spring will bend backwards at high RPM and unload the clutch disc at the worst possible time.
Now it makes sense- don't recall anything in the instructions with it about that. I need to increase the freeplay as it wears not decrease it like w/ a normal clutch. Thanks.
