Rear spring/leaf worn out?
Old Mar 31, 2009 | 08:21 PM
luisin's Avatar
luisin
Cruising
Default Rear spring/leaf worn out?
How can you tell if it´s shot? How should it look when it is ok should it be completely horizontal or leveled?
Old Mar 31, 2009 | 08:54 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
As soon as the rear of your Vette sits low enough to look cool the spring is usually worn out.
What is the angle on the half shafts ?
Old Apr 1, 2009 | 07:28 PM
luisin's Avatar
luisin
Cruising
The halfshafts are some 10º upwards I would say.... and the leaf is horizontal. I need to get the rear higher and considering geting a composite leaf of medium strengh maybe some 360 Lbs. Any recomedation I will really apprecite. Thank You.
Old Apr 1, 2009 | 10:05 PM
PEPresnell's Avatar
PEPresnell
If you spring is horizontal it is woren out. I would go with the composite spring, they give a better ride.
Paul
Old Apr 2, 2009 | 02:25 AM
Carl Granquist's Avatar
Carl Granquist
Default rear leaf spring
I kept with a stock replacement, and the photo shows the solid "new" arch as opposed to the worn-out "old" leaf spring. By the way, the old spring was essentially flat when installed and under load. Thirty eight plus years will do that to you.
I can't speak to the composite spring difference since I didn't go that route, but plenty others have.
Old Apr 3, 2009 | 05:12 PM
luisin's Avatar
luisin
Cruising
Thanks alot for your replys, very helpfull and the pics too. My spring is definetly shoot so I just ordered a new spring from duntov motor company it is fiberglass and epoxy,340 lbs. very lightweight and a good price I think.
Old Apr 3, 2009 | 06:41 PM
MN-Brent's Avatar
MN-Brent
If it is the TRW style spring, you will have ride height problems in the rear. Do you know what spring you bought?
Old Apr 4, 2009 | 01:50 PM
luisin's Avatar
luisin
Cruising
Yes it´s the TRW style spring since I have had height problems (too low) since I bought the car I hope if it becomes too high it will be easier to lower a little. Also the body of my car probably weights more than the the 79 vette original, take a look at the picture in my profile, our body is a replica of a 1936 Mercedes 540K, so maybe I should be in the Mercevette forum but haven´t found it yet.
To Rear spring/leaf worn out?
