heater cooling fan stopped
Old Apr 1, 2009 | 11:17 AM
John1979's Avatar
John1979
Default heater cooling fan stopped
It did work! I had blown a fuse while working around the console(rear defogger). after replacing the fuse I noticed the fan stopped working, I checked the fan fuse looked good replaced anyway. still nothing. checked and cleaned contacts on fan speed control and the climate control. I than took the fan relay located in the engine compartment apart. when I put the contacts together the fan runs one speed all the time even with the car off. Help please I know I did something wrong just can't figure out what it was. Thanks!
Old Apr 1, 2009 | 02:32 PM
kunkle's Avatar
kunkle
Are you sure you didn't disturb any wires/ grounds for the heater switch while you were in the console? You know the motor works, and seems unlikely the relay would be bad.
Old Apr 1, 2009 | 05:10 PM
John1979's Avatar
John1979
I checked and rechecked the connections in and around the console. But your right I had to of knock something, I haven't gotten to the fuse box, I had noticed a red wire that had been attached through the front of it at the heater fuse. I don't think this was factory and I might of knock it loosening the wire on the back of the fuse block that goes to the heater set up. I've been putting this off. lots more I could loosen. Need the rain to stop, no garage yet. that's being built next week . thanks kunkle
Old Apr 1, 2009 | 07:29 PM
kunkle's Avatar
kunkle
A garage will be great. I'm thankful for 2 car garage w/ heat- now if I only had a floor lift.......
I see you're in Huntingdon- I went to Juniata.
Old Apr 12, 2009 | 08:58 AM
John1979's Avatar
John1979
I had checked the fuse at least four times you couldn't see it was blown. replaced works great.
To heater cooling fan stopped
