Need A/C electrical help
Old Apr 1, 2009 | 08:24 PM
BassCat's Avatar
BassCat
Default Need A/C electrical help
1977 L48, factory air. Guys, I need your help. I have installed a new compressor, accumulator, etc, and recharged the system. It blows nice, cold air, but I have run into a snag. The compressor will not cycle, and it runs constantly, causes the line to freeze. I don't know if bubba worked on it before I bought it, but here's how it's set up. It has a thermostat cut off switch mounted next to the accumulator, with two wires coming off of it, but I just discovered they are not attached to anything. The thermostat sensor is attached to the a/c line. I'm assuming when it reaches a certain temp, it opens and closes the switch to shut off the compressor, but as I said, the two wires are not tied into the compressor. The system also has the low pressure shut off switch that screws into the a/c line along the passenger firewall. Two wires come off of this switch. One goes to the compressor, and the other goes into the wiring harness. I can manually shut off the a/c for 5 seconds and the ice on the line thaws out, so I'm convinced this system should be cylcling on and off. What I need to know is how do the two wires from the thermostat tie into the compressor or the cut off switch. It's a green wire and a light blue wire coming off the thermostat switch, located next to the accumulator. Where do they go?? If anyone has a '77 with this setup, could you look under the hood and let me know, take a picture, or direct me to a wiring diagram. I'm so close to having this thing work right, it's driving me nuts.
Thanks,
Kenny
Old Apr 1, 2009 | 08:26 PM
BassCat's Avatar
BassCat
P.S. The thermostat cut off switch and the low pressure cutoff switch are also brand new.
Old Apr 1, 2009 | 09:26 PM
noonie's Avatar
noonie
There are a number of switches that can be used to make up a system.
From your description yours seems to have what I call a freeze switch. Hook it up in series with the other.
Slightly more modern systems have a high/low pressure cutoff switch and also a low pressure cycling switch mounted on the accumulator.
If both the switches you have are 2 wire then just wire them in series and it should work.
Old Apr 1, 2009 | 10:09 PM
SIXFOOTER's Avatar
SIXFOOTER
If the pressure switch works all you have to do it put it in series with the compressor clutch. I don't have the drawings, but if you pm papawana he will send you what you need
Old Apr 1, 2009 | 10:24 PM
dannyman's Avatar
dannyman
Here's offer from papawana;
http://forums.corvetteforum.com/c3-g...or-anyone.html
Old Apr 2, 2009 | 06:04 AM
BassCat's Avatar
BassCat
tttt
Old Apr 3, 2009 | 10:14 PM
mds3013's Avatar
mds3013
http://img39431.pictiger.com/images/17922216/
here's the haynes diagram.
To Need A/C electrical help
