Exhaust header temp / color?
Old Apr 3, 2009 | 12:38 PM
ShaneLU97's Avatar
ShaneLU97
Default Exhaust header temp / color?
Put on my new hooker headers and sidepipes this winter and now starting to run the car, test some other mods, etc. (they are the ceramic coated versions, btw).
When I get the car warmed up I see a small glow on a few of the pipes so I am wondering is this bad? I have a wideband AF gauge and the car is running slightly rich. I also have an IR temp sensor and they are reading between 450-650 degrees.
Is this is within normal operating rage?>
Old Apr 3, 2009 | 01:45 PM
QuicheLorraine's Avatar
QuicheLorraine
Sure it is. If you see a 'slight glow' and you know it's a tad rich then there is no problem at all. When breaking in a cam & running 20 minutes at 2500RPM, you'll see headers get BRIGHT RED. Doesn't hurt them a bit.
Old Apr 3, 2009 | 03:03 PM
Duke94's Avatar
Duke94
Same thing happened to my Hookers. Problem was the timing, had to advance it more.
Old Apr 3, 2009 | 09:50 PM
Jack Wood's Avatar
Jack Wood
Default Check that ignition timing - sounds retarded. Really heats
up the exhaust valve and header. Read the timing post up top of this discussion board for advice.
To Exhaust header temp / color?
