Cutting spring top or bottom?
When you go to reinstall the cut coil, align the top of the coil in the perch-pocket of the frame, you'll see the missing paint on the frame pocket where the coil had been resting its original end cut, and let the bottom fall where it may in teh control arm.
Ive done this about 8 times now with this method and it works every time.
Good luck, have fun, and be safe!!
Not my word, but that of Dick Guldstrand, "The closed end of the spring goes in the upper pocket." Seat the top properly and let the cut end (bottom) fall where it may in the lower A-arm pocket.
TSW
I know theres a good "how to" guide out there with pictures. I reccomend finding it and study it before starting the task..
On one, I cut the top and on the other the bottom. Doesn't really matter, it depends on how much you want to drop it. One coil cut from the top will lower it less than a coil from the bottom. Cutting a complete coil will seat them like original, if it works for you.
Put car on stands under the front horns (I place them under sway bar mounts).
Remove wheels.
Remove sway bar links.
Remove shocks.
Remove tie rod end from spindle or adjustment sleeve (count threads if doing sleeve, will need front alignment anyway).
Cut wooden spacers same width as front rotor to space brake pads, remove lower bump stop and remove caliper and hang behind front wheel with wire.
Place jack under a arm. Snug for safety.
Remove nut for top ball joint. Clean threads and lubricate so you can tighten finger tight.
Reinstall ball joint nut leaving 1/4" space between nut and spindle arm.
Use puller to loosen top ball joint. The spring pressure will help pop the joint loose and the nut will keep it from completely separating.
Jack up a arm to loosen and remove nut.
Slowly lower a arm and spring will come out.
This is a good time to clean up the sloppy welding splatter etc on the frame and a arms and repaint that area etc. Also to replace the lower control arm bushings for a couple bucks apiece and/or lower ball joints.
Cut spring with metal abrasive cutting disk on a grinder/circular saw and clean and paint etc. I use Rustoleum semi gloss oil base.
Mark position of spring end for pocket with masking tape.
Reinstall spring using an internal spring compressor (can rent it).
I clean all threads also use copper antisieze on all threads.
Reverse order to assemble.
Get front end alignment.
The hardest part for me is cleaning all the parts.
Remove wheels.
Remove shocks.
I notice you used a spring compressor in the photo but didnt mention that in the details? Will the spring still drop out without compressing it any?
Great post NOONIE!! Gotta love pictures.
