In a nutshell: the starter is reving the engine and gas is flowing to the carbuerator, but the engine will not start. Not a cough, not a sputter, nothing.
Back Story: The battery always tended to drain when the car was left unused for a while. We installed a batter shut-off-switch to prevent this, but I forgot to switch it off last time I drive the car.
A week later, the batter was too low to turn over the engine. Got the car started once with jumper cables, but a couple minutes after disconnecting the other car battery, the Corvette engine died and would not start again.
Took the battery into Autozone, where they charged it and said it was in good shape. Put it back in car, and it got the starter going, but the engine still would not run. After a few minutes of trying, the battery ran down again.
So, power gets from the battery to the starter, but there is no internal combustion. Could there be some kind of power drain preventing the spark plugs from firing? Any ideas?
My choke is disconnected, so I have to manually shut the valve until I get my new carb on this month. After sitting a few weeks, it takes probably 15 seconds to fire up.
Sounds like a fuel delivery issue. Filter or pump perhaps?
If you have fuel as indicated then you need to check for spark at the plugs. Remove a spark plug; connect the spark plug electrical lead to it and have the engine turned over, while the spark plug is grounded at the threads and look for a good spark.
Make sure you have fuel and electrical. Removing one or the other means no ignition.
pull a plug wire, and slide the boot back exposing the metal tip,
and hold it about 1/4" from Gnd.
have some one crank the engine, do you get spark ?
keep you hands back, away from from the tip !
Do you actually see gas shot from the carb. when you push the accelrator ?
If you have spark and fuel I would suspect the alternator.
You say it started at one point while you were boosting it and once you disconnected the booster cables it died. thats typical if the alternator is bad. The car (spark plugs) will spark off the battery until the battery has no more juice. Or in this case disconnecting the cables.
I thought I had this problem solved months ago, but now it is back.
After replacing the distributor cap, the car started for a while. Then after sitting for a week or two, it would not start. Same situation as before: battery is charged, starter is working, gas is going to the engine.
I figured I must have left some wires loose when replacing the distributor cap, but I didn't have time to deal with it that day. I went back a week later, jiggled all the wires, made sure nothing was loose, and the car fired up like there was no problem. I let the engire run a few minutes to charge the battery.
Went back two days later (yesterday) and again the car would not start.
Considering that this problem comes and goes, where would you look first? The distributor? The alternator?
If the car is still in the wet garage the moisture could have collected in the cap again,check the points for moisture. Check to be sure the coil is firing by removing the coil wire from the distributor and holding the end about 1/2" from one of the shield brackets and have some one crank the engine and watch for a spark.
I had this problem. Turned out the starter was drawing too much current , made the battery act 'dead' even after an all night charge or a long drive. Make sure your ground cable to the frame is GOOD . STARTER
I am not getting any spark from the coil wire even though the coil is brand new. I checked the ignition wire before connecting it to the coil's positive terminal, and it definitely has juice flowing through it. The coil warms up when trying to start the car, so electricity seems to be getting into the coil.
Also, checked the distributor but saw no sign of moisure.
By the way, the distributor contains an after-market ignition module. Mallory is the brand name - the kind with three wires coming out of it: red wire goes to positive terminal on coil; green wire goes to negative terminal on coil; brown wire goes to engine ground.
I want to thank everyone who's been offering suggestions. As you can tell, I don't know this stuff well at all, so help is appreciated.
Got my hands on a diagnostic tool - which indicates a problem with either the Mallory Unilite Ignition module or the distributor pickup.
I saw a message board for Ford Mustangs where people were complaining that the Mallory module was prone to giving out very suddenly. Has anybody encountered this with a Corvette?
different question, different answer...clean the negative battery connection under the car on the transmission cross member. does wonders for cranking power....
