C3 frame question
Old Apr 5, 2009 | 11:43 AM
madmax396's Avatar
madmax396
Default C3 frame question
Are all the C3 auto trans frames similar enough that they can interchange? I'll be doing a frame off on my 71 454 auto car starting next fall. I'm collecting parts now. My current frame seems pretty rusty in the rear, past the rear axel. There is a local guy selling a perfect, rust free 76 frame for rear cheap, like $400. Just want to know if it will work in my 71.
Old Apr 5, 2009 | 01:07 PM
Alan 71's Avatar
Alan 71
I believe there are many differences but the most obvious would be that the front and rear of the frames differ depending on whether the frame was for a chrome bumper or a later rubber bumper car. So I'd say you should be looking for a 73 or older frame.
Regards,
Alan
Old Apr 5, 2009 | 01:49 PM
71coupe454's Avatar
71coupe454
I got issues with my frame so NO they not the same! I dont know what year 4-speed frame the previous owner stuck under it but the ends of the frame are giving me grief with radiator install.. most issues can be worked around most likely but watch out. theres a lot of frame repair info in here IF you can find it..
Old Apr 5, 2009 | 01:50 PM
wfo76's Avatar
wfo76
Regards,
Alan
Parts Books shows one automatic frame from 69-73, another for 74, and another for 75-77.
Don't know what the differences are but probably only in the bumper bracket areas.
Old Apr 5, 2009 | 02:02 PM
tfi racing's Avatar
tfi racing
It will work,but it must be modified.You will have to change out the rear 18" or so of the 76 frame to make it work with your 71,and may have to relocate a hole or two at the front for the brackets.
Old Apr 5, 2009 | 02:35 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Pictorial frame history...
http://www.71corvette.com/frames.html
Old Apr 5, 2009 | 03:05 PM
Alan 71's Avatar
Alan 71
TSW,
A very nice collection of pictures that illustrate something that takes a lot of words to explain!!!
Regards,
Alan
Old Apr 5, 2009 | 03:10 PM
wfo76's Avatar
wfo76
That link says the 73 frame was modified to compensate for the rubber body bushings that began
in 73. Might be true but I wonder why the parts book shows the same frame 69-73?
Old Apr 5, 2009 | 04:10 PM
madmax396's Avatar
madmax396
How! that was awesome, thanks guys.
Old Apr 5, 2009 | 04:12 PM
avner's Avatar
avner
I have a Frame diagram for 1969-1974 & unique 1968 Frame diagram, no much deference between them.
Avner
Old Apr 5, 2009 | 05:27 PM
stpman's Avatar
stpman
Avner
The 74 is a 1 year only frame, if you check the chassis diagrams the body mount heigt changed in 73 and the 1 year only 5 mph bumper slider brakets for 74. not sure how much changed on the front in 73 for the rubber bumper
Old Apr 5, 2009 | 07:02 PM
72LS1Vette's Avatar
72LS1Vette
I originally thought that the mounts were moved 1/2" or so to accomodate the rubber mounts, but after comparing drawings it looks like the mounts were only lowered 1/16" to 1/8". The bumper mounting plate holes require modification for a pre-73 body but it's not that big of a deal.
Rick B.
Old Apr 5, 2009 | 07:26 PM
BB72's Avatar
BB72
As mentioned the 76 frame will need a 68 to early 74 rear 18 inches or so and probably the front frame horn bolt holes modified also. The 74 year came with the 68 to 73 rear crossmember in the early part I believe and the later had the boxed rear section. Most tranny crossmembers allow the 4-sp tranny and shifter mount to be bolted on. Also the mounts as mentioned were lowered a bit. Correct me if I'm wrong.
Rob
Old Apr 5, 2009 | 07:50 PM
71coupe454's Avatar
71coupe454
why dont you get some pics of your rust issues on here and see what these guys in here say about saving your original frame. I wish I had had the chance to decide on the old frame on my car before the previous owner stuck this other frame in there and left the issues for the next guy, ME! lol I have to drill some holes for the outer bumper supports and also do some cutting on the ends of the frame and hope the radiator/shroud will clear then. Thats what I have found SO FAR. Some rust repair of equal effort may be worth it to keep the frame original. Good luck with the project! Heres a good link... http://corvette-restoration.com/
Old May 25, 2009 | 12:55 AM
glennjr91's Avatar
glennjr91
good day, i have a 1980 vette, side rails are rusted.. don't have much cash, can this be repaired without a total frame reconditioning.... i have seen inter and outer frame rails, will this work> thnks, glenn
To C3 frame question
