Carburetor Setup Tch Sheet
Old Apr 5, 2009 | 11:51 AM
SoCalErv's Avatar
SoCalErv
Army
Default Carburetor Setup Tch Sheet
Does anyone have a good tech sheet to properly set a quadra jet. I have a 69 and have a slight miss or stumble at idle.
I have rechecked the timing and replaced the sprak wires. Never really like touching the carburetor but it is next on my list.
Thanks.
Old Apr 5, 2009 | 12:33 PM
a1sensei's Avatar
a1sensei
99% probability that stumble is your accelerator pump (if it is stumbling as you start to go). Take the air cleaner lid off. Then look down the primary bores as you pull the throttle linkage. There should be a strong stream of fuel (like a squirt gun) shoot into each primary barrel. I bet one or both streams will be weak, sputtering or non-existent.
God bless, Sensei
Old Apr 5, 2009 | 01:20 PM
SoCalErv's Avatar
SoCalErv
Army
God bless, Sensei
No problem accelerating. I just have this issue at idle. It will drop 50 - 100 rpms for a second and recover the repaeats in a cycle.
Old Apr 5, 2009 | 02:13 PM
Peterbuilt's Avatar
Peterbuilt
That might be caused by your vacuum advance can or the centrifugal advance but heres a basic how to for a Q-Jet www.4wheelnoffroad.com/qjet.html search for Lars papers for the best carb info. PG.
To Carburetor Setup Tch Sheet
