Valve cover paint
Old Apr 5, 2009 | 07:46 PM
micmak's Avatar
micmak
Default Valve cover paint
What sort of paint should you use to freshen up the valve covers? Can you use regular automotive spray paint in a can, or does it need to be heat resistant engine paint?
.......Mike.......
Old Apr 5, 2009 | 07:48 PM
another-user's Avatar
another-user
i sprayed on high temp last year, works just fine.
Old Apr 5, 2009 | 07:56 PM
SEVNT6's Avatar
SEVNT6
I use Dupli-Color engine enamel for everything under the hood. I've done my intake & firewall with it. Good stuff..........
Old Apr 5, 2009 | 07:58 PM
ROBRICCI's Avatar
ROBRICCI
used the same paint as i painted the engine with - no problems so far...
Old Apr 5, 2009 | 08:06 PM
71coupe454's Avatar
71coupe454
High temp engine paint from auto zone works ok. I would like to try powder coating some stuff, get my 220 ran to my garage I will be lookin for a oven.
Old Apr 5, 2009 | 10:42 PM
bailey228545's Avatar
bailey228545
Not to hijack the thread, but sevnt6, do you have another shot of the inside of your engine compartment. I had planned on dressing the compartment on my '81 up , but that got put on hold. Looking at starting up with that project within the next couple of weeks and liked the way yours looks. Especially with the way you have managed to hide most all of your wires.
Old Apr 6, 2009 | 12:19 AM
birdsmith's Avatar
birdsmith
That's a REALLY pretty big block there with the exception of that little clear glass fire starter spliced into the fuel line....please don't put it into yout Vette like that!
Old Apr 6, 2009 | 12:29 AM
SEVNT6's Avatar
SEVNT6
Thanks bailey228545.... You have a good eye. Things I've hid or removed: Headlight door vaccum lines under the M/C. I took all 10 feet of washer hose out along with the bottle. Hid my wipers under the cowl cover since I don't do rain. Ran all of the wires that go all over the top of the A/C box into the firewall & ran 'em back out over the blower motor. No stickers. I even molded the firewall smooth. I'd also never do all of this work again............
Hope you don't mind the pics micmak........
Old Apr 6, 2009 | 12:35 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
I use high temp engine paint....
Old Apr 6, 2009 | 08:03 PM
micmak's Avatar
micmak
You hope I don’t mind the pics???? Are you crazy??? Some beauties there SEVNT6! I have a related question about the valve covers: What sort of gaskets do you guys use? My covers are not perfect and they leak a little. They are warped, I guess. Will a cork gasket help to solve my problem or is there some other material which will help to solve my problem?
Thanks guys.
......Mike......
Old Apr 7, 2009 | 01:34 PM
SEVNT6's Avatar
SEVNT6
Thanks micmak..... I've always used cork. The main thing is to not overtighten. And even then with time they will leak again.....
Old Apr 7, 2009 | 05:26 PM
micmak's Avatar
micmak
Isn't there something that will last?? I used cork a couple of seasons ago and they worked fine for a while, but gradually the leak returned. It's as if the gasket degrades and eventually leaks. I use a valve cover bolt reinforcement set too, but it really didn't do much to prevent the problem from returning. Is there some sort of silicone-based gasket that might last longer?
BTW, when I say "a couple of seasons", it's worth rembering that I only drive about 1,000 miles each season!! So the cork gaskets are not very satisfactory at all!
......Mike......
Old Apr 7, 2009 | 06:38 PM
SEVNT6's Avatar
SEVNT6
There are rubber ones out there but I've never tried them. One thing I know: My L-82 covers don't leak near as bad as my steel ones did. They've been on for a few years now & are just starting to leak a little at the back. I found mine at a swap meet for $100 & then had 'em chromed.....
Old Apr 7, 2009 | 09:18 PM
vetteguy75's Avatar
vetteguy75
I've been using rubber/steel gaskets for years.....never had a leak or problems.
To Valve cover paint
