Transmission jack prices
Old Apr 7, 2009 | 08:11 PM
my75baby's Avatar
my75baby
Default Transmission jack prices
I am about to remove the 4 speed borg warner tranny in my 75 vette, can anyone recommend a good tranny jack? and for how much and who sells it? I hope this will only be a one time event.. thanks
Old Apr 7, 2009 | 08:15 PM
Gordonm's Avatar
Gordonm
You really don't need one. They are not that heavy. I had my Muncie in/out many times without one. If you do want one though.
Do you have the car on a lift or on jackstands. When I got my lift I bought a tall one for auto transmissions. I bought it from Greg Smith equipment in Deleware. I think I paid about 80 or 90. I got it in a package deal. I think he also has some low rise ones also. Check out his website. http://www.gregsmithequipment.com/Tr...Jacks-s/27.htm
Old Apr 7, 2009 | 08:21 PM
Red 71's Avatar
Red 71
From: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
About the cheapest I have seen is this one from Harbor freight. It attaches to a floor jack.
http://www.harborfreight.com/cpi/cta...emnumber=39152
I have this one that I have used for a few years for auto's to 5 speeds.
http://www.harborfreight.com/cpi/cta...emnumber=39178
Old Apr 7, 2009 | 08:33 PM
Red 71's Avatar
Red 71
I am a old fart and I remember pulling a trannie out of a 50 Ford on the side of a hill in Ohio on Thanksgiving weekend (light snow). In later years the first time I used a trannie jack I thought I was cheating!!
Old Apr 7, 2009 | 08:35 PM
Duke94's Avatar
Duke94
I have the scissors type from Harbor Freight as well. It works great when you are doing the job alone (and you are old like me!).
Gary
Old Apr 7, 2009 | 09:04 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Boy we could have used a trans jack this weekend here. We installed a new clutch in my sons Camaro Z28. Let me tell you that T-56 is one heavy mother when you are not used to hefting one around. We used the floor jack but it is still a lot of work.
Old Apr 7, 2009 | 09:18 PM
tfi racing's Avatar
tfi racing
IMHO a tranny jack on a T-10 might be more trouble than its worth.The T-10 only weighs about 60 pounds,a second pair of hands for a beer or two would be my preference if I couldn't do it myself.
Here's the place I usually have to wrestle a T-10 out of,no way to use any kind of jack on this one!
Old Apr 7, 2009 | 10:22 PM
my 76 ray's Avatar
my 76 ray
I haven't used either of these but I would think the first one that fits on a floor jack would be harder to position since the front two wheels on the jack are not casters.
Old Apr 8, 2009 | 08:36 AM
my75baby's Avatar
my75baby
WOW, thanks for everyone's input. I do not have a lift and I will be by myself, my concern is not too much getting it out, but putting it back in. Once i put the clutch and pressure plate in I want to line the splines up perfectly so i'm not jerking everything around when I try to re-install. Years ago I did the same thing (stronger and more patient then), I'd like to make things easy if possible. I saw the scissor type, the platform looked small, Duke when you used this, it held the tranny ok? (I know it doesn't weigh much, but even at 60 -100lbs, i'd rather not have the thing falling off onto my hand ... LOL)
Old Apr 8, 2009 | 08:37 AM
my75baby's Avatar
my75baby
One last thing, most people I talk to about removing this tranny advise that they have done so many times... I have to ask.. Why does it need to come out so often?
Old Apr 8, 2009 | 08:38 AM
jgrigg's Avatar
jgrigg
My brother just bought the first one that attaches to a floor jack. We used it when replacing a clutch in a Tracker of all things. It was adiquate, but honestly if I had the extra money I'd buy the other one. The **** is somewhat clumsy to operate.
Good luck with your decision.
Old Apr 8, 2009 | 09:39 AM
mrvette's Avatar
mrvette
Want the cheeeeeeepest solution??? a 12" piece of 2x6 with a hole in the middle, through which is placed a 3/8' carriage bolt, drill/tap the center of the jack cup with a 3/8-16 tap, screw it down, and call it a day....been using that setup for some 20 years now....
Old Apr 8, 2009 | 09:52 AM
TERRY CLARK's Avatar
TERRY CLARK
.......or you can rent one !
Old Apr 8, 2009 | 10:44 AM
7T1vette's Avatar
7T1vette
Jeez... Just buy the cheapest [China-built] floor jack at Auto-Zone, put the plate under the lowest point on the bottom of the case and hold the tail housing while you jack it up or down. What's the problem?
Answer to your question...$20. [and then you have an extra, light-duty floor jack]
Old Apr 8, 2009 | 10:45 AM
Garys 68's Avatar
Garys 68
Thought I was the only one.......
But mine was more high tech. 1' x 2' piece of plywood. Bolt through the center. My jack already had a bolt hole from a removable jack cup.
Then 2 pieces of 2 X 4 screwed into the plywood to hold my ROD upright.
Old Apr 8, 2009 | 11:04 AM
Duke94's Avatar
Duke94
Can't beat that for low cost solution. What I found useful with the scissors type jack is that I can put my pneumatic ratchet on the screw and raise and lower it with ease. I’ve removed plenty of Muncies with no jack, but that was in my younger days. I installed a TKO in my 78', and never would have gotten that beast raised up without the jack.
Gary
Old Apr 8, 2009 | 11:20 AM
The Money Pit's Avatar
The Money Pit
I did a th350 once by laying the tranny on my stomach, skotching under the car and bench pressing it up into place,.....alone. I know I was nuts, but I was 18, and money was tight. No funds for a jack then.
Last one I did was the th400,......I cheated.
Old Apr 8, 2009 | 12:34 PM
GTR1999's Avatar
GTR1999
I use the HF sissors jack as well, works great when you pull the diff too.
To Transmission jack prices
