Check out these Plugs
I started out checking the carb, carb gasket, vacuum leaks, ckd valve lash, timing, pulled distributor to re-shim end play and replace vacuum advance, checked the plug wires and so on. Looks like there are several problems here, oil fouled plugs, bad graphite Delco plug wires, possible some carb issues. Motor is mostly stock .030 over 350, 9.6:1 CR, stock heads with Z-28 springs and L-82 cam, AC Rapid Fires with cusotm duct tape tags
[IMG]
[/IMG][IMG]
[/IMG]Can put new, hotter plugs, new wires and see what happens.
But too, if you found some bad wires, those weren't firing and could have oil fouled becasue of that.
After thinking and looking again, I'm not sure I wouldn't just pull the heads. I'm thinking that they may have stacked some oil rings.
thanks
