rear leaf spring bolt length ??
Old Apr 8, 2009 | 08:31 PM
YankeeStation1967's Avatar
YankeeStation1967
Default rear leaf spring bolt length ??
pic deleted
thanks, here is a pic of the old spring
Old Apr 8, 2009 | 09:28 PM
dannyman's Avatar
dannyman
OK! How did you break it?
Don't know the bolt size but it should be easy enough to measure new compared to old and shorten to fit.
Old Apr 8, 2009 | 10:00 PM
dannyman's Avatar
dannyman
All these bolt sizes are different depending on the spring used; 7 leaf, 9 leaf, mono etc...
Having bolts that are too long is great because you can use the grinder to size. Can't you re-use what is in the car now, if shortened?
You may need to identify which specific spring you intend to install so someone can answer your question.
To rear leaf spring bolt length ??
