Improving My L48
Old Apr 10, 2009 | 10:03 AM
ntmd8r3's Avatar
ntmd8r3
Default Improving My L48
I have a 77 with the L48. I don't want to get crazy and I don't have a lot of money to spend. What I want to do is improve the performance, but control my budget. I have about $1500 to work with. It already has a true dual exhaust but it has dual converters as well. I am thinking of replacing the heads and have read the other threads discussing the Procomp route, so I don't want to go there. I have been looking at Summit Racing and the have a reasonable price on a set of their performance cast iron heads which they say are cast the same as "double hump" heads or thier aluminum heads which are not priced to badly either. I have a edelbrock performer cam that I am adding to the mix as well. I am not expecting a 400hp C6 killer, I just want improved performance from what I have. I really don't want to get to extreme as it is the original block, and it appears to have had a rebuild prior to my purchasing the car a year ago.
Old Apr 10, 2009 | 10:22 AM
jackson's Avatar
jackson
Seems you are doing the work with $1500 on hand for part&pieces.
GM iron Vortec heads.
Felpro 1094 head gaskets.
Summit K1103 cam&lifter kit.
Professional Products 52007 vortec intake manifold.
-edit-
or
GM aluminum L98/ZZ4 "113" heads.
GM 10105117 head gaskets.
same 1103 C&L kit.
along w/ YOUR OE intake manifold.
Duke94's Avatar
Duke94
Here's a start.
Gary
Old Apr 10, 2009 | 10:27 AM
jbowles49's Avatar
jbowles49
Check out this kit from Scoggins Dickey
http://www.currymotors.gmmotors.com/...cHeadKits.aspx
Good Luck
Old Apr 10, 2009 | 11:00 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Dump that cam, never heard anything good about it, probably there's someone out their that likes it though
Sportsman II heads
RPM Air Gap intake
Comp Cams Magnum 270H
Steel shim head gasket to get compression up
Old Apr 10, 2009 | 11:05 AM
pauldana's Avatar
pauldana
i would use the RPM roller cam.... I have it and I love it!
To Improving My L48
