Brake bleeding question
Old Apr 11, 2009 | 09:04 PM
1Fordman's Avatar
1Fordman
Default Brake bleeding question
Wrapped up the rebuilt trailing arm installation today (thanks GTR1999!) and bled the brakes using the MityVac which has worked well on other vehicles in the past.
Went through 2 quarts of fluid and still getting air out of the system. Bled inside rr, outside rr, inside lr, outside lr, rf and then lf.
Had a great pedal before all of this. Installed new ss calipers, rotors, pads and all new hoses. The m/cylinder was 6 months old so it wasn't replaced.
Pedal can be pumped up so it's definitely air.
Is an exorcism needed or am I missing something in the bleeding procedure?
Old Apr 11, 2009 | 09:07 PM
midyearvette's Avatar
midyearvette
you know, i switched to speed bleeders about 3 years ago and swear by them now.....one man operation and no mess to clean up..your bleeding sequence is correct....good luck....
Old Apr 11, 2009 | 09:15 PM
dannyman's Avatar
dannyman
If at any time throughout the bleed procedure your fluid level dropped too low then you will have to remove and bench bleed the master cylinder. Any chance you got too low?
Old Apr 12, 2009 | 12:14 AM
1Fordman's Avatar
1Fordman
Fluid level in m/cylinder never went below 1/2 full.
Old Apr 12, 2009 | 12:15 AM
1Fordman's Avatar
1Fordman
Thanks midyearvette, I might just make that my next method of attack.
Old Apr 12, 2009 | 12:37 AM
trsulliv's Avatar
trsulliv
Watching the Master cylinder lfuid level key. Another area to watch is the other end of the bleeding process, the bleeding tube.
Not sure how you are exaclty bleeding the brakes, but if you are using the pedal, I always make sure the tube running from the bleeder in brake fluid in your catch conatiner so that you don't suck air back in between pedal strokes. To be really sure, close the bleeder each time your assistant has the pedal on the floor, then release the pedal. I have a bleeder tube with a check ball at the end that goes into the container - a double check to make sure you don't suck air in.
Old Apr 12, 2009 | 01:38 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Throw away that mity-vac thing, and get yourself a Motive power-bleeder, it will be the best $60 you have ever paid for your vette. I can bleed my brakes alone and get a rock hard pedal in less than 10 min.
Old Apr 12, 2009 | 02:25 AM
thegavel's Avatar
thegavel
I made a "power bleeder " from a piece of alloy, some rubber &
air fitting(you could use an old M/C cover and drill 2 holes).
I use a G clamp to hold it in place.
Attach air line(Don't crank the pressure too high),
crack open bleeder valves.
Did my whole system in 1/2 an hour.
Sure it's crude, BUT it works.
Hope this helps,
CHEERS
Gav
Old Apr 12, 2009 | 08:13 AM
larryg3's Avatar
larryg3
i have tried the mity vac but have noticed that even though it creates a good vacuum it also lets air get past the bleeders. the threads of the bleeders are not air tight when they are open. I prefer the two person method. i usually ask my son to step on the pedal and bleed the brakes. However we DO NOT PUMP THE PEDAL. as this aerates the brake fluid. We just simply open the bleeder and push the pedal down close the bleeder and repeat until all air is gone. and you do have the right sequence. rr lr, rf, lf
Old Apr 12, 2009 | 08:57 AM
dannyman's Avatar
dannyman
It doesn't take much air to make the pedal spongy. Sometimes air bubbles get hung up on internals at calipers, distribution blocks, etc... Rapid pumping of the pedal at times throughout the bleed process during the two man operation is intended to release the little buggers! Gentle tapping of the brake components with a rubber mallet is supposed to do the same. Don't give up!
Old Apr 12, 2009 | 09:16 AM
08vycpe's Avatar
08vycpe
Also be sure to leave the pedal depressed as you close the bleeder then have your helper let up on the pedal. If the helper takes his foot off the pedal when the bleeder is open air will enter.
Old Apr 12, 2009 | 11:34 AM
GDaina's Avatar
GDaina
Do a gravity bleed....submerge the tube in the catch can and let the fluid trickle out by itself...and watch for air bubbles...on the rear calipers, two bleed screws, do both...when no air, move to the next wheel...gravity bleeding takes a longer time. When done, system is free of air.
Old Apr 12, 2009 | 11:44 AM
1Fordman's Avatar
1Fordman
Thanks to all of you for the good advice and tips. I think I'll try the gravity method and if that fizzles, buy the Motive bleeder.
The old MityVac has worked great on other vehicles but everything has it's match. It looks like the MityVac met it's match in the blue beast!
Old Apr 12, 2009 | 12:25 PM
GDaina's Avatar
GDaina
mity vac is good to start the bleeding, once fluid appears, then switch to gravity.
Old Apr 12, 2009 | 12:38 PM
ksbunting's Avatar
ksbunting
I have the mighty vac also and read several times on this forum that other guys have said the mighty vac is so powerful it pulls air past the rubbers in the caliper so it actually does more harm than good.
I did mine by gravity in my 68 and I have perfect rock hard brakes with Dot 3 fluid
Kurt
Old Apr 12, 2009 | 07:47 PM
1Fordman's Avatar
1Fordman
Received a few PM's and Motive seems to be the way to go. So now it's off to Amazon and ebay to see who has the best deal. Or if anyone has a good recommendation on who to purchase from, let me know.
Thanks again guys for all the good info received. Will use the MityVac as a vacuum tester only from now on!
Old Apr 12, 2009 | 08:11 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Seems like I have read on here where someone took the bleeder screws out and greased the threads so the air could not be pulled by. I have not tried it but thought it seemed believable. Anyone else try this?
To Brake bleeding question
Old Apr 12, 2009 | 08:46 PM
1Fordman's Avatar
1Fordman
Default Motive brake bleeder
Ordered the Motive Magnum 0350 model, 4 quart capacity and 3 adapters for 99.00 delivered.
Thanks again for the advice and those that PM'ed with the Motive recommendatrion.
Old Apr 12, 2009 | 10:22 PM
LanceB's Avatar
LanceB
I use the Motive also and it makes the whole job much easier! One question I had is I was wondering if I should put anti seize on the bleeder valve threads or not.
Old Apr 13, 2009 | 10:04 AM
my 76 ray's Avatar
my 76 ray
I put grease on the bleeder screw threads as the last step in bleeding the system. I do this because I have broken many a bleeder screw after they have rusted into the calipers. The few times I have had to bleed calipers where I have used the grease I have never broken a bleeder screw. By the way, anti seize didn't work for me.
