Front End Alignment Issue
Old Apr 14, 2009 | 12:01 AM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
Default Front End Alignment Issue
Did a search, nothing camjecte up this sub. My toe is at 3/32 (.085) toe out. What does toe out do for handling? Car handles OK, but not great.
Camber was at 1/2* positive camber on the left side and 1* positive camber on the right side, able to bring both sides down to 1/8* positive camber.
Need to adjust the rear camber. Visually has a negative camber. Set it at 1/2* negative camber 3 years ago after the rear suspension rebuild. Car has settled, Hence the change in camber.
Mark
