Guys,
I am struggling to find a threaded rod to fit my 750 Speed Demon for the air filter. I emailed them and got a reply that it was 5/16th 32 TPI, now 32TPI is a very fine thread and it looks nothing like that. I have tried all the non-metric threads at my disposal but still cannot find the right one. Any suggestions?
Just standard 5/16 coarse thread. Should be 18 threads per inch. I just used a standard threaded 5/16 threaded rod available anywhere, at least here in the states.
What if you just got a tap and tapped the hole to fit some Metric threads and some rod you can find?
Or we can get Joe to bring one over next time he comes!
JIM
I have thought of that Jim, but stripping and cleaning the carb after made me hold off. I havent worked in Moscow for over a year so Joe may have difficulty finding me, unless he comes to Scotland of course.
I just need to find the correct thread, I tried 5/16th UNC, UNF, AF etc.
I was previously told it was 9/32UNC but no, emailed BG and they told me it was 5/16th 32TPI which made no sense. I will have another go with the thread guages again, but because its femail thread its easy to get it wrong. One more go before I go the metric route.
that my scottish friend requires a 5/16 stud kit. gordonM is spot on about the threads per inch and that any speed shop should sell it. dont go tapping anything. if your desperate do a mail order through BILLET SPECIALTIES or somewhere like that, they have them in stock.
Thanks guys,
I did try, when trying to size the thread, a 5/16th 18tpi tap,amongst others, but it caught after a turn or so. I only used finger tightness, but it was enough to throw me. (As did the email from BG saying it was 32tpi!!!) I can get 5/16th UNC rod here by special order so when it arrives I shall run my tap through to clean up the thread before I fit it. Crazy how sometimes you can get led off at a tangent
typical BG phone service saying that... lucky their carbs HAMMER !!!
be sure to hold up your tap against your piece of rod to make sure its a perfect match. taps always seem to grab like that. i think it must be why people say never use a tap to clean out head bolt holes when installing new heads.always use an old head bolt as a tap will remove some of the exhisting material even though its the correct one.
