Intake and carb fitment
Old Apr 14, 2009 | 08:38 PM
Grumpy 427's Avatar
Grumpy 427
Default Intake and carb fitment
I bought a new Edelbrock 2701 dual plane intake and 1406 carb. First i noticed that the dual snorkel air cleaner will not fit on the carb, the electric choke and fuel fitting hit the bottom of the air cleaner. I am going for the free Air cleaner deal Edelbrock has on right now when you buy a new carb.
What are you guys using for air cleaners with this set up? And does it fit under the stock 1980 hood.
Old Apr 14, 2009 | 09:09 PM
Jeff_Keryk's Avatar
Jeff_Keryk
I use play dough to check clearance. The Edel Air Cleaner is pretty low profile. You might use a shorter filter.
Old Apr 14, 2009 | 11:25 PM
Grumpy 427's Avatar
Grumpy 427
I am thinking 2-3 " filter should do?
Old Apr 15, 2009 | 04:58 PM
FRSTR90's Avatar
FRSTR90
is the 2701 a performer or performer RPM? I was running a performer rpm manifold with a stock L88 style drop base with a 4 in element in my '73. The fit was tight, but no clearance issues. Being that the hoods on an '80 aren't as tall as a '73-'79, I think you would clear fine with a 3in element. If you think about it, it is the exact same set up as a '70-'72 LT1. The hood of a 80 and a 70 LT1 hood are approx the same height, the performer rpm is the same design but an improved version of the LT1 manifold. The only difference I see is the choice in carb. Edelbrock makes a banjo fitting if you want to run a rubber line and/or a pre-bent steel line to clear drop base air cleaners.
Old Apr 15, 2009 | 10:18 PM
spikebot 81's Avatar
spikebot 81
Grumpy, I have the very same setup on my 81. I fabbed a 1/4" thick ring to fit on top of the carb to space the dual snorkle air cleaner. Everything clears no fittment problems. I have seen carb spacers at auto supply but they are way too tall. By the way I used square stock for the spacer and bent it in a circle with the vise and a torch
Old Apr 16, 2009 | 12:06 AM
Grumpy 427's Avatar
Grumpy 427
The 2701 is a performer intake, it is a square bore too, so you can run a holley or an Edelbrock carb. I do have a 1/2 spacer ring from a previous setup. i will try that once i get the new motor back in the car.
Old Apr 16, 2009 | 06:36 AM
Fishndude's Avatar
Fishndude
I have a Perfomer RPM intake and LT-1 hood and the only air cleaner I can find that clears is the one in my photo (click on "my corvette photos).
Old Jan 19, 2011 | 08:33 AM
springer89's Avatar
springer89
Grumpy 427- did that 1/2" spacer worker?
i am putting the same intake and carb on my 79 and want to run the stock air cleaner. thanks.
Old Jan 19, 2011 | 08:38 AM
MrJlr's Avatar
MrJlr
I'm running the 1406 carb too...
I'm using the Edelbrock triangluar air cleaner
Stock '74 hood barely closes....
To Intake and carb fitment
