Edlebrock Intake Install
Old Apr 15, 2009 | 04:03 PM
cruzzin-style's Avatar
cruzzin-style
Default Edlebrock Intake Install
I need to know if anyone has ever intsalled an Edlebrock Intake part # 2701 on their 350 & if hood clearance was an issue. I plan on using a holley 3310 carb. that a universal carb. I also have the LT1 factory hood, that's the same as the 454 & 427 factory hood. I hoping that someone will share their experiences with on this. Thanks in advance to everyone
Old Apr 15, 2009 | 05:08 PM
GeorgeS's Avatar
GeorgeS
Cruzzin, Edlebrock told me to install either 2101 or 5001 in my 68. I chose the 5001. I have a 327 with a stock hood. Let's see if someone else pipes up here...
Old Apr 15, 2009 | 05:13 PM
SH-60B's Avatar
SH-60B
I can't remember model numbers, but i have a performer intake/ Edelbrock carb. Dropped base with 2" element leaves about an inch with a factory smallblock hood.
Old Apr 16, 2009 | 11:55 AM
Al Davis's Avatar
Al Davis
I have a 79 Vette and I am running a Performer egr and L82 Qjet. I have a drop base air cleaner. No problems.
Old Apr 16, 2009 | 04:27 PM
cruzzin-style
I want to install the Edlebrock 27034 intake which is the EnduraShine one. It looks pretty much like the 2101 which is the universal intake for the SBC. I'm just wondering if the 27034 is higher than the OEM stock 350 LT1 4 barrel intake.
Old Apr 16, 2009 | 04:51 PM
cruzzin-style
George: What carb are you running? How much clearance do you have from hitting the hood?
the 2101 looks to be a slightly lower rise than the 2701. Front rise is 3.50 & rear rise is 4.60 on the 2101, whereas the front rise is 3.74 & rear rise is 4.80 on the 2701. Edelbrock claims either one will work under the stock hood, but I just wanna be sure.
Anyway, there doesn't look to be much difference between the older stlye 2101 & the newer 2701. Wish I knoew for sure.
cruzzin-style
Old Apr 16, 2009 | 05:20 PM
Ganey's Avatar
Ganey
cruzzin-style
For perf., the previous 2101 or 2701.
Edelbrock tech. on current 2101 "our current generation produces more street friendly low end torque."
Old Apr 16, 2009 | 06:19 PM
Quil's Avatar
Quil
I'm running the Edelbrock Performer RPM with a Holley 650DP and it clears the stock hood fine with a drop base aircleaner in my '75.
Old Apr 16, 2009 | 06:32 PM
Ganey's Avatar
Ganey
73-79 have the med. rise hood & more clearance than early models.
RPM w/ DP.
Old Apr 16, 2009 | 07:49 PM
Quil's Avatar
Quil
RPM w/ DP.
Gotcha...I totally spaced on the "LT-1 hood" comment in the first post.
Old Apr 16, 2009 | 07:55 PM
Ganey's Avatar
Ganey
LT-1 had a 2" drop base.
Old Apr 17, 2009 | 05:34 AM
worship79's Avatar
worship79
Have the 2701 on my '79 with EDL 1411 carb (no spacer) and stock snorkel airfilter: fits perfectly.
Old Apr 17, 2009 | 08:34 AM
Fishndude's Avatar
Fishndude
I have the 2101 and same holley 3310 with an LT-1 hood and the max air cleaner height from the flange is 3" and that includes the wing nut.. As mentioned in a above post, you could use a drop base too.
Old Apr 18, 2009 | 01:05 AM
cruzzin-style
Default Thanks FishnDude
FishnDude - So what year?
If your running the 2101 - the 2701 is approx. 1/2" higher rise than the 2101. If you say you got 3" clearance, then I should be "good to go" using the 2701 with the 3310 carb. I'm gonna be using the drop base air cleaner. Actually, it was a "Stock" air cleaner cut down. So, my base is the stock OEM drop base.
Thanks again for posting.
Cruzzin-Style
Old Apr 18, 2009 | 05:21 AM
Fishndude's Avatar
Fishndude
Cruzzin-Style
68
If you look in "my corvette photos' you will see my motor with a 3" air cleaner on it..
Old Apr 19, 2009 | 09:42 PM
cruzzin-style
Originally Posted by Fishndude
68
FishnDude: Nice "Ride". I use to run 15x8 Cragars & white lettered tires on mine for a long time. But, now I'm redoing the car & opted to go to 17x8 billet aluminum rims.
The car's still under construction Been working on it for quite awhile. Keep running outta "cash"
But, I'm finally getting the major stuff done. Paint, motor, trans, etc.
you know how that is.
Someday, I'll have pics to post too !
So, I'm gonna order the 27034 Intake like I want. It's the EnrduraShine one with the oil fill tube.
When I get that intake, it will replace the one I have now. I was using a stock OEM 327 intake from a 1966. That one will be For Sale, if you know anyone looking for one.
I also got a set of OEM 350 heads. The double hump ones; the "power pack" heads. They're in good shape, but would probably need freshing up.
Thank for posting "FishnDude"
cruzzin-style
Old Apr 19, 2009 | 09:43 PM
cruzzin-style
Default Thanks to everyone
Many thanks to everyone who posted to my thread about edelbrock intakes fitting under the stock early LT1 hood.
cruzzin-style
To Edlebrock Intake Install
