Gear ratio calculator
Old Apr 16, 2009 | 11:20 AM
QuicheLorraine's Avatar
QuicheLorraine
Default Gear ratio calculator
How to use one with a slippery torque covertor? I've always figured my '76 to have a 3:08 rear end but now I'm wondering. It was a virginal 50K mile L-48 car when I started restomodding it. So I'm sure the original owner never put a 4:xx rear end in it. Yet that's what the couple of gear ratio calculators I've tried are showing. I used to use SmokeEmUp's website but now it's fee based. So I just googled a couple and ran the numbers.
I figure the reason I'm getting bad info is because of my 2500 stall convertor.
Using 27" tall tires (255/60r15) and a Turbo 350, it runs 3400RPM at 65MPH. By then the convertor has certainly gone into full engagement, so I don't know why the gear ratio calculators show gears so low.
Old Apr 16, 2009 | 11:31 AM
avner's Avatar
avner
If you want to know what is the rear end ratio put the back two wheel on air and count how many turns make the driveshaft for one turn of the wheel this will be your ratio in the rear end, by that you eliminate other errors or faults.
Avner
Old Apr 16, 2009 | 11:45 AM
Gordonm's Avatar
Gordonm
Avner
With a loose converter there is to much room for error using a gear ratio calculater. Your tach could be slightly off also. This is a sure fire method.
Old Apr 16, 2009 | 12:03 PM
QuicheLorraine
Actually I disregarded my tach completely as it's useless. It reads way WAYYY higher than it should. I was watching the tach on the Dyno yesterday when they were setting the cruise mode on the carb. It was run quite a while at 65MPH with a few different jet settings, to get the best setup possible. They spent a lot of time doing carb setup as I know these guys very well (used to be service manager there for a while). So anyway that's where the 3400 RPM came from. My tach read closer to 5000.
RE: spinning the driveshaft-sure that's an easy way but I don't think it's precise. Certainly though, one could tell a 3:xx gear from a 4:xx gear. That's for sure. You wouldn't be able to tell a 3:23 from a 3:08 though.
Old Apr 16, 2009 | 12:28 PM
gerry72's Avatar
gerry72
Originally Posted by QuicheLorraine
..You wouldn't be able to tell a 3:23 from a 3:08 though.
It would be slightly more difficult if you were blind, but even then you could tell by your tactile senses. If you know the available ratios, you will have enough information to deduce the result. You'd have a convincing agruement if the distinction was say a 3.08 to a 3.10 ratio.
Old Apr 16, 2009 | 12:29 PM
wfo76's Avatar
wfo76
You can make a pointer for your driveshaft if you need to. There is no 3.23 Corvette ratio, they went 3.08, 3.36, 3.55, etc and you should be able to see the difference between a little over 3 turns and 3 1/3 turns. You could also spin the tire 10 times and then the driveshaft would turn either almost 31 or 33 1/2 times.
Old Apr 16, 2009 | 01:34 PM
QuicheLorraine
Now that makes sense. I've looked on the Diff. for markings but cannot read any. Driveshaft spin, here we come!
To Gear ratio calculator
