oil leak around distributor
Old Apr 16, 2009 | 03:36 PM
painterman52's Avatar
painterman52
Default oil leak around distributor
How can I stop the oil from leaking around the distributor and manifold? I have a gasket but it doesn`t seem to work very well.
Old Apr 16, 2009 | 04:05 PM
pauldana's Avatar
pauldana
bad gasket.... are you sure you have the round donut gasket on the distributor?
Old Apr 16, 2009 | 05:10 PM
SeattleC5's Avatar
SeattleC5
You might also want to make sure that you are not leaking oil from the gasket between the intake manifold and block at the back of the engine below the distributor. If that is fine then a nice new distributor gasket is needed.
Old Apr 16, 2009 | 05:52 PM
Peterbuilt's Avatar
Peterbuilt
Is your oil pressure sending unit up there? They can leak too. PG.
Old Apr 16, 2009 | 07:05 PM
SteveG75's Avatar
SteveG75
Use a little non-hardening sealer on the distributor gasket. That will help seal it as well.
Old Apr 16, 2009 | 07:53 PM
painterman52
Is there a specific brand or name for the sealer?
Old Apr 16, 2009 | 08:13 PM
pauldana's Avatar
pauldana
ooooo, and i did remember, on mine there is a place to put an oil sending unit near the distributor, although I have a plug there, it was leaking, and it could look as if it were coming from the distributor, put teflon on the plug and had no problems since..
To oil leak around distributor
