spark plug wires keep burning up from header heat
Old Apr 16, 2009 | 08:27 PM
pauldana's Avatar
pauldana
Default spark plug wires keep burning up from header heat
have already gone to the shorty Accell spark plugs, have tried both 90deg, and straight plug connectors, put heat boots on the plug wires, and they still fry and break down in about 500mi... or so....
the wires I have been using are Malory 8.5 both 90 deg and stright, spiral wound.
Is there a better plug wire/boot that can take the header heat?
thx.
Old Apr 16, 2009 | 08:42 PM
PeteZO6's Avatar
PeteZO6
If they are routed like in your avatar, try running them under the headers. Heat rises, so by running them low, the heat won't get to them as much. I have Moroso Blu-Max spiral wound under my Hookers. I did put some heat insulation around the wires passing under #4 & #6 pipes because the clearance is tight there. The rest of the wires are uncovered, just routed carefully. They are uncovered and still pliable and supple. So far, so good.
Old Apr 16, 2009 | 08:45 PM
fugawi's Avatar
fugawi
if your plug wires are routed over the headers as in your avatar. i'd suggest going under your headers. your plug wires are about the best you can buy.heres a pic of how mine are.
Old Apr 16, 2009 | 09:26 PM
mrvette's Avatar
mrvette
90% chance that in fact the OP is referring to the BOOT over the plug end of the wire....and those are the primary failure point over which little or no control exists for the installation....
the only cure I know of is Jacobs ceramic boot ends....
cured my problems....
I fill the ends going into the ceramic with RTV that seals out ALL moisture of ANY type....
Old Apr 16, 2009 | 10:22 PM
midyearvette's Avatar
midyearvette
hey paul...check "baby's " total timing..many times a retarded or incorrect curve in the dizzy will do exactly what you have.....other posters are correct in routing and that you have a premium wire set....the fact that the mill is not over heating and the wires are, is a good indication of slow timing...good luck......
Old Apr 16, 2009 | 10:24 PM
midyearvette
nice detail!!
Old Apr 16, 2009 | 11:45 PM
chvet73's Avatar
chvet73
Mine run just like yours do. I purcahsed insulation boots from Summit. There are several styles. Have had no problem since I added the boots.
Old Apr 17, 2009 | 12:56 AM
RIJVETTES's Avatar
RIJVETTES
Good move. Cheap insurance.
Old Apr 17, 2009 | 09:48 AM
pauldana's Avatar
pauldana
Yep.... you got it... Are the Jacobs ceramic as good as the MSD for spark properties? are the spiral wound?
FUJAWI...... VERY nice looking!! but I do not think the under thing will work any better, being it is the boot itself that is frying!!!
chvet73... Already running them... not enough, but helps.
Old Apr 17, 2009 | 09:56 AM
TopGunn's Avatar
TopGunn
If the above hasen't worked out you might want to look at the 'Wrench Rat" extension. It does require about the same room as the boot but it's porcelain. I have one and it seems to do the job but they're a little pricey if you need to do the whole motor.
http://wrenchrat.com/sparkarm/
Old Apr 17, 2009 | 10:21 AM
pauldana's Avatar
pauldana
Looks as if that would work... $30 each does seem high, but buying new plug wires all the time is also pricey.... I would also like to know more about the Jacobs ceramic wires...I am very tired of dealing with this all the time...
Old Apr 17, 2009 | 10:42 AM
jimvette999's Avatar
jimvette999
I switched to the orange/rust colored high temp boot ends from MSD with good results.... the grey silicone MSD boots fried/crystalized even with fiberglass sleeves
http://beta.summitracing.com/parts/MSD-8852/
Old Apr 17, 2009 | 11:41 AM
Jeff_Keryk's Avatar
Jeff_Keryk
In the past I have dimpled the headers. The Summit Insulators are pretty cheap.
pauldana's Avatar
pauldana
That looks like it may work... did you use them? did it fix your problem? did you just cut the old boot ends off and crimp the new ones on?
thx...p:-)
Old Apr 17, 2009 | 02:05 PM
jimvette999
thx...p:-)
I certainly did use them.... just took a razor blade and split and slid grey silicone boots off, used a little di-electric grease on the crimped wire ends and slid new boots on. 3 years now and not a scorch to be found. They are extreme duty high temp compound. If those hadn't worked I was going to use the porcelain ones.
these are the grey ones I took off
http://store.summitracing.com/partde...5&autoview=sku
Old Apr 17, 2009 | 02:26 PM
pauldana's Avatar
pauldana
Yea... the grey is what I have also... Seems to be a cheaper fix than the ceramic Jacobs wire... I guess if it works that is all that is needed..., I will order them today unless someone chimes in that they also have problems. Then post the results... I getting tired of fixing the same problem over and over again...
But.... thoes Jacob wires do sound good... hmmmm think thin think...
Old Apr 17, 2009 | 04:17 PM
jimvette999
I replaced several grey boots before finally finding those red ones. None of mine are/were making direct contact with header, just close proximity. These red ones have a thinner wall and sleeker shape and don't get as close as the fat grey ba$tards did. Good luck...
To spark plug wires keep burning up from header heat
Old Apr 27, 2009 | 04:05 PM
pauldana's Avatar
pauldana
Ordered them today. hope they work... found 4 boots split last night from the heat... you can tell, the car runs like CR#P..... Next stop may be ceramic headers...
ps..the jacobs are not red... bummer... need red p:-)
Old May 2, 2009 | 12:15 PM
pauldana's Avatar
pauldana
ok... i ordered the boots, put them on last night and will give a update in about 2 weeks... the old grey boots on the MSD wires usually only last for about a 4 hour search and destroy ferrari/Lambo run... Before they char and break..
Old May 18, 2009 | 04:21 PM
pauldana's Avatar
pauldana
Last update on this unless something goes wrong or a question is asked.
I changed the spark-plug boots to the high heat ones mentioned above, I also have the fiberglass booties on that cover the rubber high-heat boots. Took it on a grueling 6 hour run in 100 degree wether, checked the boots... All is good... the grey boots would have been TOAST, I mean chard toast! and these new red ones seem and look fine. ... so, problem solved... new high heat boots and fiberglass boot covers, no char--so far.
