antenna a ground??
Old Apr 16, 2009 | 10:44 PM
red70stingray's Avatar
red70stingray
Default antenna a ground??
Question....
Positive wire on a radio to hot power wire, then plug in the antenna,
does the antenna act as a ground and the radio will play???
On a 70?
Old Apr 17, 2009 | 08:20 AM
Alan 71's Avatar
Alan 71
Hi R70S,
Why don't you PM... Jerry - Radio Guy... I'm pretty sure he can help you out with some info.
Regards,
Alan
Old Apr 17, 2009 | 09:43 AM
Ganey's Avatar
Ganey
Connect radio to gnd. The antenna is actually half & should be grounded as it uses the metal frame as the other half- ground plane.
Old Apr 17, 2009 | 08:11 PM
Jerry - Radio Guy's Avatar
Jerry - Radio Guy
R70S, the center lug on the power connector on the side of the radio is for a ground connection. The lug towards the front of the radio is +12 volts for the radio power and the lug towards the rear is for the dial lamp and is powered from the dash lighting circuit.
As Ganey said, make sure you have a ground connection back to your battery from the radio case one way or the other. There are plenty of grounding points under the dash.
Good luck!
Jerry
_____________
Alan, HI!
To antenna a ground??
