Picture request
Old Feb 1, 2002 | 11:22 AM
Chris@VetteFinders's Avatar
Chris@VetteFinders
Platinum Supporting Dealership
Default Picture request
Could some post a picture, or email me one, of your battery tie down setup in your C3? Mine is missing all of the hardware for it.
[Modified by Rhys, 10:23 AM 2/1/2002]
Old Feb 1, 2002 | 11:36 AM
Noel Carboni's Avatar
Noel Carboni
Default Re: Picture request (Rhys)
I don't have a photo handy, but in my '82 the battery restraint boils down to a little plastic/composite block with a hole in it, and a bolt that goes through and threads into a nut in the floorpan.
The battery has slots along the bottom. The front slot engages into something in the front of the compartment, and the bolt/block pushes into the back slot.
Hope this helps.
-Noel
[Modified by Noel Carboni, 3:37 PM 2/1/2002]
Old Feb 1, 2002 | 12:11 PM
Chris@VetteFinders
Default Re: Picture request (Noel Carboni)
Kinda, but mine looks a little different than you describe. A pic would sure help.
Old Feb 1, 2002 | 08:37 PM
78Vette-SA's Avatar
78Vette-SA
Rhys, do you have the AIM or would you like a picture?
Mine were actually busted out when I got it. I bought new rivets (the big fat suckers) and hammered them in. Then I bought a new clamp and bolt.
One edge of the battery gets tucked under the lip in the front, then a clamp and bolt go behind the battery if I'm remembering correctly. Poor car has been covered since mid-october. It's killing me! :mad
Old Feb 1, 2002 | 09:00 PM
Chris@VetteFinders
Default Re: Picture request (78Vette-SA)
You know what page it is on in the AIM?
Old Feb 1, 2002 | 10:08 PM
daniel77350's Avatar
daniel77350
mine works the same as described as above, however I had to put my battery up on a block in the compartment, because before I fixed my rear window leak, it used to leak and the water ran down into the batt compartment. :eek: :eek:
Now I have the leak fixed, but I havn't had time to fix the setup and put it back to normal.
Daniel
Old Feb 2, 2002 | 01:10 AM
78Vette-SA's Avatar
78Vette-SA
453 :seeya
Old Feb 2, 2002 | 09:52 AM
killain's Avatar
killain
Oldtimer
Hay Rhys, it's on page 450 of the AIM, but it only shows the plastic block, it needs a 5/16-18x 2 bolt that goes through it, into the screw block in the base plate.
Old Feb 2, 2002 | 11:47 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: Picture request (killain)
Bubba long since trashed mine....but what you're describing sounds a lot like the battery hold downs GM used on my '89 Sub, '78 Pontiac and '86 Pontiac....maybe even my '67 Firebird.
I think I still have a left over screw & Rubber hub. If you want I'll take a look later.
Len
Old Feb 2, 2002 | 11:56 AM
Chris@VetteFinders
Default Re: Picture request (1970 Stingray)
Looks like I am missing that rubber clamp and the screw. I'd appreciate that Len. Let me know.
Old Feb 2, 2002 | 12:25 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
You have mail
Old Feb 2, 2002 | 01:59 PM
killain's Avatar
killain
Oldtimer
I think i have an extra rubber block if you need it Rhys .
Old Feb 2, 2002 | 02:17 PM
Captain Morgan's Avatar
Captain Morgan
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
What are the dimensions of the battery? What brand? My battery doesn't seem to have the lip to tuck under anything at the bottom. I would love to be able to use the hold down for it, just need the right battery.
Old Feb 2, 2002 | 02:18 PM
killain's Avatar
killain
Oldtimer
Default Re: Picture request (sharklover)
AC delco 70DT-60
Old Feb 2, 2002 | 02:29 PM
Captain Morgan
Cruise-In V Veteran
Thanks, you're quick. BTW, I posted a reply to your cat converter topic. Probably not quite what you wanted, but maybe it will help.
Old Feb 2, 2002 | 07:29 PM
Chris@VetteFinders
Killain, Len says he does not have one for me. You have an extra?
Old Feb 2, 2002 | 11:19 PM
killain's Avatar
killain
Oldtimer
Rhys, I'm pretty sure I have out in the garage, I'll go out in the datlight and see If in fact I have one. I kinda sure I do. Hang on.
Old Feb 3, 2002 | 12:06 AM
Chris@VetteFinders
Tried to send you an email and it bounced. My cost for the hold down is less than $2 and I have to order some other stuff anyway. No need to trouble you to ship it. It will cost you more than it will me.
Thanks for going through the trouble though.
Old Feb 3, 2002 | 10:17 AM
killain's Avatar
killain
Oldtimer
Well OK, But I found it this morning. :yesnod:
To Picture request
