Door Gap Adjustments
Old Apr 17, 2009 | 02:34 PM
dp1969's Avatar
dp1969
Default Door Gap Adjustments
The driver side door of my 69 Coupe has a significant gap between the Top Left door and where the left front quarter panel meet up with it. It appears that if you were able to lift up the bottom right rear of the drivers side door it would fix it. My question is, are there adjustments other than the 8 bolts holding the door onto the flippy hinge? I realize these cars were not so good with the panel fit, but this should be better. The passenger door is near perfect. There are no door panels or glass in right now so I can see everything...Just no other adjusters
Old Apr 17, 2009 | 03:48 PM
Peterbuilt's Avatar
Peterbuilt
If you open the door about 1 foot and lift up on the rear bottom of the door does it move? If it does than new hinge pins and bushings might help. PG.
Old Apr 17, 2009 | 04:18 PM
dp1969's Avatar
dp1969
No, it is very solid, no slop
Old Apr 17, 2009 | 04:54 PM
zwede's Avatar
zwede
Both sides of the hinge are adjustable. The part of the hinge that bolts to the car can also be adjusted.
To Door Gap Adjustments
