help with horsepower..if you will.
Old Apr 19, 2009 | 02:18 AM
whitelightning94's Avatar
whitelightning94
Default help with horsepower..if you will.
ok i know you get this question alot. and i searched to see if i saw a combo like mine to keep from asking again. but i missed it if it was out there.
so, if you will. help me guesstamate the horsepoweri might be making.
383
weiend team G intake
comp cams XE294H
1.6 roller rockers
AFR 195cc eliminator heads
holley 750
9.9:1 compression
long tube headers, 2 1/2in duels
MSD HEI, 6AL ignition
ive prolly forgot something you need to know.
so just tell me and i'll add it
thanks in advance guys.
Old Apr 19, 2009 | 01:09 PM
cboyd's Avatar
cboyd
I'll try to get a chance to do a few calculations later tonight. I'll need to check the specs on the heads, chamber volume and flow rates.
Clyde
Old Apr 19, 2009 | 02:22 PM
C3 Stroker's Avatar
C3 Stroker
This link may be helpful. AFR dyno tested combos:
http://www.airflowresearch.com/store/chevy_dyno.php
Old Apr 20, 2009 | 12:24 AM
whitelightning94
thank you much guys. and id greatly appreciate that Clyde.
i also looked at the AFR website. i was thinking i was similar to the 383 with 503hp. but im not sure how different i'll be since i have a hydraulic cam.
Old Apr 20, 2009 | 07:03 AM
Ganey's Avatar
Ganey
ABOUT 480+, roller cam about +17+.
Old Apr 20, 2009 | 04:46 PM
Shirley1978's Avatar
Shirley1978
how much hp would he potentially lose if he ran 1.5 rockers instead of 1.6?
just asking because im going to be running almost the same set up but with
286HR comp cam
stealth intake
and 1.5 rockers
Old Apr 20, 2009 | 08:28 PM
C3 Stroker's Avatar
C3 Stroker
286HR comp cam
stealth intake
and 1.5 rockers
Your peak horsepower may be similar, but your torque curve will be different (flatter, and will pull better from lower RPM's due to roller design). Yours won't sound as radical (less duration), but it won't need as much converter in an automatic. My guess is about 5 HP potential gain with 1.6's, as these cams seem to be optimized well for their combos.
Old Apr 21, 2009 | 09:57 PM
cboyd's Avatar
cboyd
Hey white lightning'
Sorry it took so long for me to get back to you. I ran your specs but only used 1.5 rockers.
I am a little unsure how to rate your intake..Single plane std. flow or single plane high flow so i ran it with both.
Single plane std. flow:
Max. H/P = 441 @ 6000 RPM
Max. T/Q = 436 @ 4500 RPM
Single plans high flow:
Max. H/P = 483 @ 6500 RPM
Max. T/Q = 446 @ 5000 RPM.
Hopes this helps. A roller cam would help you out some, but those AFR's are some head. I am also building a 383, but I am using Edelbrock E- Tec 200cc. I can't hit that H/P klevel. I am still playing with diffrent cams.
Good luck
Clyde
Old Apr 30, 2009 | 01:04 AM
whitelightning94
thanks for the replies guys. and thanks so much Clyde.
im hoping my intake counts as a high flow because i was shooting for at least 475..but 44-450 will work for now if not. and as for a roller cam...i would like to. i just cant see speeding the money at this time. in the next year or 2 im going to change cams and add a procharger supercharger, so i may go roller then..we'll see.
again tho..thanks guys.
To help with horsepower..if you will.
