temp senders
Old Apr 19, 2009 | 07:19 PM
lilypad's Avatar
lilypad
Default temp senders
Just got my motor back and man it looks sweet. But the guy put plugs in on both sides of block and two sensors in a baggie, one has two spades and one has round button plug on the end what goes where, and what color are the wires supposed to be thanks for the help?????
Old Apr 19, 2009 | 08:19 PM
Peterbuilt's Avatar
Peterbuilt
The round button plug is the water temp sender, it goes between #1 & #3 spark plug.
The two spade sender is for the TCS (Transmission Controlled Spark), it went between #6 & #8 spark plug but you can leave that one off. PG.
Old Apr 19, 2009 | 09:01 PM
JimT's Avatar
JimT
For the temp sender, look around the alternator wiring harness for a long wire that has a "plug" on it. Some temp senders are mounted in the head between the #1 and #3 spark plugs, and some are mounted in the intake manifold next to the thermostat housing.
To temp senders
