U-Joint with or without grease fitting?
Old Apr 19, 2009 | 07:36 PM
73 stingray's Avatar
73 stingray
Default U-Joint with or without grease fitting?
I am looking at buying new u-joints for my 69. Can you guys tell me your opions on witch U-joints are better?
With grease fitting or without the fittings?
van steel has with grease fittings for 22.99 and without for 27.99 does that make sense or what am I missing ?
Thanks Jason
Old Apr 19, 2009 | 07:40 PM
speedreed8's Avatar
speedreed8
the ones without the gr. fittings are usually HD, stronger. i always replace the halfshaft units with non greaseables. the other ones are prone to break under hard acceleration.
Old Apr 19, 2009 | 07:52 PM
midyearvette's Avatar
midyearvette
Old Apr 19, 2009 | 09:24 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Old Apr 19, 2009 | 09:34 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
It's not that black and white. What are you using your car for? I've run both types of u-joints in my '69 over the years. Never had a problem with either type. Road course stuff is my thing, so my drivetrain isn't subjected to hi-RPM clutch dumps on a regular basis.
Unless your '73 is extremely warmed over, you're probably fine with either type.
Old Apr 20, 2009 | 08:03 AM
GTR1999's Avatar
GTR1999
Use Spicer solids, 5-799x. Just be careful installing them. Look up my thread on how to do the job and you'll be ok.
Check a local dealer they may stock them.
Old Apr 20, 2009 | 10:09 AM
wcsinx's Avatar
wcsinx
Duntov has the Spicer solids for $25 a piece and they don't charge shipping. I haven't found them cheaper anywhere else.
http://www.duntovmotors.com/Differentials_63-79.htm
Old Apr 20, 2009 | 11:57 AM
spinadog's Avatar
spinadog
Have to agree, great pricing (Duntov) and all the experienced folks I chatted to recommend Spicer.
Old Apr 20, 2009 | 01:09 PM
Rally68's Avatar
Rally68
Get the Spicer solids from Duntov, look up GTR1999's post with pictures of how to install, and get on down the road
Old Apr 20, 2009 | 01:52 PM
MN-Brent's Avatar
MN-Brent
Bruteforce U-joints are solid non-zerk type and have a good rep from the 4X4 crowd.
I'm presently using them at all 6 locations and am quite happy with their longevity.
You can pick these up at most parts stores, if they have your size. Let your fingers do the shopping.
Old Apr 22, 2009 | 08:50 PM
73 stingray
I am looking also at Autozones duralast gold. not grease fitting they are 17.00 and lifetime
Old Apr 23, 2009 | 09:56 AM
Rally68's Avatar
Rally68
This is my 2c and nothing more BUT
that's a false economy. Duntov sells the Spicers for $50/pair for the halfshaft joints, with free shipping, and $46/pair for the driveshaft joints. If you don't believe me call your nearest driveline shop. I'm betting they will tell you $8 bucks more for the Spicer joint is money well spent. I recently did mine, and the difference in quality between the joints that were on the car (they were replacements, not factory, put on by a PO, don't know the brand) and the Spicers was obvious.
Old Apr 23, 2009 | 10:09 AM
wcsinx's Avatar
wcsinx
And I put that in the same category as 100,000 mile warranties on Korean cars.
Wouldn't you rather have something that won't break in the first place?
Ujoints aren't a place to cheap out. If they go, they can cause a lot of damage in the process, and you're dead in the water.
To U-Joint with or without grease fitting?
