'68 turn signal problem - what to do next?
Old Apr 20, 2009 | 03:22 AM
Linas's Avatar
Linas
Default '68 turn signal problem - what to do next?
Hello,
When the turn signal on my '68 suddenly stopped working, I though, it would be an easy fix. Just replace the flasher in the fuse box and I'm done. As it did not solve the problem, I decided to replace the turn signal switch assembly, as the turn signal switch was kind of lose and the hazard light switch **** was broken. When I did that and put new switch & wiring, to my dissapointment, the turn signal did not start working... Hazard lights are working fine.
Anyhow, if I place turn signal **** into "left" or "right" position and then press the brake pedal, only one side brake light goes on - the side, to which the turn signal **** is switched.
Any ideas, where to go next??? Many thanks in advance for helping me out
Old Apr 20, 2009 | 03:56 AM
avner's Avatar
avner
Check the grounds on the 4 lights housing at back.
Avner
Old Apr 20, 2009 | 04:12 AM
Linas's Avatar
Linas
Avner
You mean, at the back of each corner turn signal light? :o
Old Apr 20, 2009 | 04:24 AM
avner's Avatar
avner
No, I mean at the 4 lights at the back of the car, on 68 the both 2 light of each side at the back of the car are used as turn signal and brake light.
Old Apr 20, 2009 | 06:37 AM
R1234's Avatar
R1234
Also, check to make sure you have a good connection to the the half round connector at the wiring harness.
Old Apr 20, 2009 | 07:34 AM
Linas's Avatar
Linas
Thanks, I doublechecked this one, as I was assembling the steering column after turn signal switch change. Now I will look at 4 lights in the back, if grounding is ok.
Old Apr 20, 2009 | 09:44 AM
john roth's Avatar
john roth
And isn't the signal light flasher on the passengers side ?
The flasher on the fuse box should be hazards
JR
Old Apr 20, 2009 | 09:45 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
The turn signal flasher relay is not located in the fuse box. It's located under the cig. lighter in early 68's and behind the pass. dash on later models. You replaced the hazards relay.
Old Apr 20, 2009 | 12:43 PM
timemender's Avatar
timemender
Replace the turn signal flasher and see if all the lights work properly.
Old Apr 21, 2009 | 01:05 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Well, did you fix it?
To '68 turn signal problem - what to do next?
