broken antenna on 76 ?
Old Apr 20, 2009 | 09:11 AM
ripforrey's Avatar
ripforrey
Default broken antenna on 76 ?
I have broken antenna with the cable and grounding plate hanging down by the muffler. How does the grounding plate & antenna attach to the underbody?
Old Apr 20, 2009 | 09:24 AM
Duke94's Avatar
Duke94
Should be a cap that screws on from the top. #3 in the picture.
Gary
Old Apr 20, 2009 | 11:45 AM
billsfan's Avatar
billsfan
You install the antenna from the bottom, sandwiching the ground plane between the antenna and the body. Then you install the antenna trim piece with gasket from the top, followed by the nut. The trim piece must be angled properly with the body. Be sure the ground strap from the ground plane to the frame is connected.
Old Apr 21, 2009 | 02:48 PM
ripforrey's Avatar
ripforrey
thanks, the parts I need are only $20. Mast, nut, etc
To broken antenna on 76 ?
