Which GAS TANK ???????
Old Apr 20, 2009 | 02:20 PM
BuddyM's Avatar
BuddyM
Default Which GAS TANK ???????
I need to replace my gas tank on a 70 L45 but not sure if I need w/E.C.C. or without. How do I tell if my car has E.C.C.??
Thanx
Buddy
Old Apr 20, 2009 | 03:30 PM
Alan 71's Avatar
Alan 71
Hi Buddy,
I believe you need to check if your car has the fuel return line on the right side frame rail (it runs right next to the fuel supply line), and whether it has the fuel vapor line on the driver's side frame rail running from the tank to the charcoal canister in the fender well, under and to the left of the master cylinder.
Here's what the connections look like. This is my base engine 71.
Regards,
Alan
Old Apr 20, 2009 | 09:22 PM
BuddyM's Avatar
BuddyM
Alan
I have both lines on the right but nothing on the left. The only canister by the brake booster is my vacuum tank. I guess this means I need the Non-E.C.C. tank???
P.S. Your rivets are in the mail...thx
Thanx
Buddy
Old Apr 21, 2009 | 06:54 PM
Alan 71's Avatar
Alan 71
The way I read the manual I believe you're right, only California, base engine, cars had the ECS in 70. So you probably shoudn't see the 'coffee can' behind the wheel well.
Regards,
Alan
To Which GAS TANK ???????
