Carburator Gurus
Old Apr 20, 2009 | 07:44 PM
76yellow's Avatar
76yellow
Default Carburator Gurus
I have a 67 Camaro 396 in my 68 Vette. It has a cast iron intake & a Quadrajet. My Question is what is supposed to be between the carb & the intake for gaskets ? I've gotten a lot of info from friends & auto parts stores & they are all different. Some say intake, gasket, heat shield, carb. Someone said intake, gasket, heat shield, gasket, carb. One said just the gasket. I tried that & it burnded up. Does anybody know for sure what I should do here ?
Old Apr 20, 2009 | 09:55 PM
a1sensei's Avatar
a1sensei
Get it from the source. E-mail Lars at v8fastcars@msn.com. He will get back to you with the right answer within a day or two.
God bless, Sensei
Old Apr 20, 2009 | 11:17 PM
76yellow's Avatar
76yellow
Thanks alot Sensei, I e-mailed Lars. I guess I forgot about him. I'm sure he will steer me right......Thanks Again
Old Apr 21, 2009 | 11:45 AM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
If there's a groove for carb heat which is visible at the carb mounting surface of the intake manifold, you need a metal heat shield to prevent burning up the carb gasket.
Old Apr 21, 2009 | 12:47 PM
76yellow's Avatar
76yellow
Thanks larry.....There is the groove so what your saying is, the thin metal heat shield first, then the gasket, and then the carb ?
Old Apr 21, 2009 | 02:21 PM
larrywalk's Avatar
larrywalk
Yes, but you'll want to make sure that there are no leaks between the heat shield and the manifold too - you can use a thin film of RTV or use a gasket with the long cutout over the groove.
Here are a few links for your reading...
http://wiki.answers.com/Q/How_do_you...on_a_1965_nova
http://www.camaros.net/forums/archiv...p/t-76070.html
http://cgi.ebay.com/ebaymotors/Mr.-G...11510004r36478
To Carburator Gurus
