On my '69 350/350 vette, I can switch the ac off using the ac control, however, the ac stays on. Is the problem likely the ac selector control switch or something else?
If the selector control switch in the off position doesn't turn the ac off, should I just remove the ac fuse to shut the ac off as a temporary fix?
Does it do it at lower fan speed settings, or only with the fan on the high setting?
Mine does the same thing but only with the fan set to the highest speed.
The high blower relay is overheating and the contacts inside are getting stuck together. A new quality high blower relay would fix it, but I can't seem to remember to order one. I will just continue to use only the lower fan speeds only until I can remember to order a new relay.
Bad switch or bad relay. Check them out individually with an ohmmeter to see if the contacts are correctly opening and closing [or if they are permanently stuck together].
One of the relay wires for the blower falls out, and grounds itself out by touching the other wires on the relay.
It's kind of hard to see, because the relay wires are facing down, but look around that area and make sure the contacts aren't loose.
It has taken me some time to get back to this. Here is my question: Can you or somebody tell me exactly where I should look? Should I look at the switch inside the car, or somewhere under the hood of the car? If under the hood, exactly where?
The high speed blower relay is mounted to the front of the A/C housing in the engine compartment on the passenger side. It has 4 wires on it, one orange, one black, one purple and one blue. It (the relay cover) may be painted black. It is held with 2 screws into the housing and the wires hang down from it.
