HEI Wiring
Thanks for the help!
Matt
I am relunctant to chime in here since there is so much conversation by people who seem to know what they are talking about. I don't want to add to the confusion.
I have a '73 with an MSD HEI, an MSD blaster coil, MSD HEI pointless tach drive distributor. MSD specifically states that you need to hook up the MSD box directly to a 12v battery source. Don't borrow power from another circuit. The threaded stud on the horn relay, driver's side fender area on the '73 is 12v battery hot all the time and I used that as my 12v battery source. Everything seems to work fine if the rest of the wiring is hooked up per the instructions.
Here are a few exerpts from my MSD owners manual:
HEAVY RED WIRE - This wire connects directly to the battery positive (+) terminal or to a positive battery junction or the positive side of the starter solenoid. Note: Never connect the alternator. I used the threaded post on the horn relay under the hood.
ENGINE RUN-ON
Here is what CF member '75 is talking about. I didn't have this problem:
If your engine continues to run even when the ignition is turned Off you are experiencing engine Run-On. This usually only occurs on older vehicles with an external voltage regulator. Because the MSD receives power directly from the battery, it does not require much current
to keep the unit energized. If you are experiencing run-on, it is due to a small amount of voltage going through the charging lamp indicator and feeding the small Red wire even if the key is turned off.
Early Ford and GM: To solve the Run-On problem, a Diode is supplied with the MSD in the parts bag. By installing this Diode in-line of the wire that goes to the Charging indicator, the voltage is kept from entering the MSD. Figure 6 shows the proper installation for early Ford
and GM vehicles.
Note
iodes are used to allow voltage to flow only one way. Make sure the Diode (it's a common 1 amp 400 volt diode) is installed facing the proper direction (as shown in Figure 6).Ford: Install the Diode inline to the wire going to the #1 terminal.
GM: Install the Diode in-line to the wire going to terminal #4.
GM 1973 - 1983 with Delcotron Alternators: GM Delcotron Alternators use an internal voltage regulator. Install the Diode in-line on the smallest wire exiting the alternator (Figure 6). It is usually a Brown wire.
Matt
Matt
