Doing your own alignment
Old Apr 22, 2009 | 04:24 PM
TERRY CLARK's Avatar
TERRY CLARK
Default Doing your own alignment
Who has done their own alignment here...........Any instructions for a '73. I just finished the rebuild on the front end and replaced a bent lower cross shaft and now I have some serious, serious tow out !
Old Apr 22, 2009 | 05:09 PM
midyearvette's Avatar
midyearvette
terry..go to duntov motors corvette website...click on alignment process..very informative and precise..good luck.....
Old Apr 22, 2009 | 05:18 PM
mrvette's Avatar
mrvette
above, OR email me/search for some links of doing it yourself...
it will take some time to set up your concrete garage floor, and to set up some simple tools, like fishing line between jack stands
and a simple ref table converting degrees into so much inches over a 15-20" rim diameter....measure off the RIM like the alignment machines, NOT off tires...
Old Apr 22, 2009 | 08:05 PM
Lotadoh's Avatar
Lotadoh
Just a quick warning. Once you get the toe set, watch the tires closely. A wrong caster setting generally doesn't wear tires, a wrong camber setting will wear tires over time, but a wrong toe setting will destroy the tires very quickly.
Old Apr 22, 2009 | 10:28 PM
3JsVette's Avatar
3JsVette
Here take a look at this http://www.carcraft.com/howto/48938/index.html I hope you find it helpfull.
To Doing your own alignment
