th400 kickdown quit
Old Apr 28, 2009 | 07:46 PM
08vycpe's Avatar
08vycpe
I learned a lot from this thread. It's really helpful when the OP trys what people suggest and reports back with the results or the final fix.
Thanks to the OP and the posters.
Old Apr 28, 2009 | 08:54 PM
TimAT's Avatar
TimAT
Originally Posted by baxsom
ok dropped the pan.
<snip>
i grounded the case straight to the neg pole of the battery and touched the actual wire to one side of a light bulb test wire and the other wire from the light bulb to the + side of the battery
the light came on but no click from the solenoid.
i guess its bad. new one is on order
If the light came on when you touched the solenoid wire then the solenoid has continuity- the coil inside it is ok. That DOES NOT mean it working properly. From your troubleshooting, I say you made the correct decision getting a new one.
Old Apr 29, 2009 | 07:21 AM
baxsom's Avatar
baxsom
yeah i went ahead and found one at the local parts house,
had to be special ordered.
i am going to assume (i hate doing that) that the new one should click when tested right? even so as bad of shape as the old one was in it needed to be switched anyway. that bare + wire was a problem in the waiting even if it was working right.
Old Apr 29, 2009 | 04:58 PM
baxsom's Avatar
baxsom
it was the solenoid inside the tranny.
new one got put in.
wired
pushed the gas pedal and click clickety click click click
thanks for all of the help
now if anyone wants to come over and help clean up trans fluid from the garage floor that would be great
Old Apr 29, 2009 | 06:23 PM
GTR1999's Avatar
GTR1999
You can actually here it click? I have to check mine, it's the original and I don't think it's downshifting.
Old Apr 29, 2009 | 07:52 PM
baxsom's Avatar
baxsom
yep
on the th400 with the ignition on crawl up under the dash and by hand press the activation switch by the pedal and listen to the tranny
you will hear a click inside the transmission if it is working correctly.
