th400 kickdown quit
i crawled under the dash with the key on and pushed the switch by hand. no click from the tranny.
i thought ok the switch is bad like last time.
i unplugged the switch and jumped the terminals from the wire.
still no click from the tranny
i got out my voltmeter.
one wire has 12v with the key on like it is supposed to.
i reconnected the plug to the switch. i put both ends of the voltmeter on each terminal and turned on the key and get a constant 12v with the switch in the up position. if i press the switch to the engaged position the volts go to 0.
any ideas on what could be wrong. it seems i get 12v going through the switch with it in the up position but no voltage with it in the down position like the pedal is to the floor.
if i take the switch out and wire it into a simple battery to light circuit
the light is off with the solenoid switch in the up position but the light goes on in the WOT position so i know that the switch itself works.
The solenoid in the tranny may have a problem.
Switch your meter to OHMS. Disconnect the switch, put one lead on each terminal and see what happens. Should show open with the switch in the normal position and then "O" with the throttle at WOT.
Also check that wire to the trans has not either come off the trans or is burned and broken.
Mine had a broken wire.
i checked under the car
there is a two wire plug going into the tranny.
one orange
one black.
the orange is the same wire that connects to the fuse box at the kickdown switch.
when i activate the switch the orange wire into the tranny is hot. when i let go of the switch the orange wire is no long showing voltage at the plug.
i can only assume that the black wire is ground. i cant get a contuity test on this wire. my voltmeter beeps if i have connection. when i connect the black wire going into the tranny to the - side of the battery i get no beep.
if that is the ground to the switch that may be the problem. but i traced the two wire harness all the way back to the firewall and cant find anything wrong.
tomorrow i am going to try and splice an temp ground into the plug and see what i get.
(just a rough description off the top of my coconut- I don't have the hydraulic diagram here)
Bax- don't forget when/if you need a new solenoid- don't forget the seal for it!
i took it out a year or so ago when i installed the transgo shift kit.
god i dont want to go through all of that again.
i did figure out that the black wire that goes into the plug is not grounded. maybe the wire broke into the harness somewhere.
i get 12v on the orange wire if i ground my multimeter on the frame.
if i stick the neg pole of my multimeter onto the black wire at the plug i do not get 12v.
(i removed the kickdown switch and am using a pushbutton switch jumped across the switch plug to connect the orange wire to the fuse box.
if the black is ground then it should have continuity with the frame.
right now the black wire outside the tranny isnt showing on the continuity checker that it is connected to the ground on the battery.
that is an outside the tranny problem. now if i put a dedicated ground and power to the solenoid that i know is good and it still doesnt click then i need to take off the pan.
i put an ohmmeter on the terminals of the solenoid.
it read 1.83
is that good or bad
fyi
i put the ohmmeter across the terminals on the tranny solenoid.
it read 1.83 whatever that means.
the wires off of the tranny.
scenerio 1
voltmeter red connected to orange wire
voltmeter black to black wire
push gas pedal and no voltage readings.
scenerio 2
voltmeter black connected to frame
push gas pedal and i get 12v on the meter
scenerio 3
+hot wire to + plug on solenoid
- ground wire to - plug on solenoid
no clicks
so it is almost beginning to look like i have two problems
the first one is the ground wire is not grounding anymore.
ok thats an easy fix. worse comes to worse i just reattach the ground wire to the frame and call it good. a little bubba but at least a temporary fix.
the second problem is that even with a known 12v and ground on the solenoid i am still not getting a click.
(i can wiggle the terminals on the tranny a bit too if that helps)
so i am going to drop the pan and test the solenoid out of the tranny and see what happens.
god i hate dealing with stuff like this but the tranny shop wants 200 bucks to drop the pan and replace the solenoid.
thats a lot of money for a 30 dollar part
i already had the drain plug in it but even after letting it drain overnight i still spilled maybe a pint when i dropped the pan out.
of course it went right on my chest. but i digress. there were technically two wires inside the case. one was the + wire to the solenid. the other explained why there was no connection to the ground. it was clipped at the terminal. i guess it used to have an extra ground.
now the solenoid grounds to the tranny valve body i guess.
anyway the wire to the solenoid was almost broken. bare wire was showing. the case to the solenoid was cracked and loose.
i grounded the case straight to the neg pole of the battery and touched the actual wire to one side of a light bulb test wire and the other wire from the light bulb to the + side of the battery
the light came on but no click from the solenoid.
i guess its bad. new one is on order
