Reverse Light Harness Hook Up
Finishing up the install on a TKO-500 auto to manual swap, was wondering if anyone could offer some guidance on how to hook up/splice the harness. Thanks!
This switch works way better than any others I have tried.
http://forums.corvetteforum.com/c3-t...witch-pic.html
There should be a pink and green wire from the outside of the dash. It has a angled connector. This is for the reverse lights. This is for a 4 speed car. The automatics have the pink/green wire on the shifter in the console.
Thanks that should help. It looks like the switch on the tranny is just a ball bearing that gets depressed when the transmission is in reverse and completes the circuit so I should be able to trace the wires around to figure it out.
