Seam in the front door jambs
I want to seal this area – should I use an adhesive or a sealer? And which type?
I just saw your post, but in anticipation I got some 3M seam sealer... dang
that stuff is expensive.... $42 for 10oz ish... but I hear its good. I see they gave me clear, but I think I best return and get black.
Thanks - I saw that the seam sealers are paintable. I was just trying to decipher from 3M which one was right.... and still confirm whether adhesive or sealer is appropriate.
Scott - I looked up the Front Pillar Cover in my AIM database and no bueno.. maybe another name\? But I am thinking it is more a cowl or fender seam. I have attached a pic (see below).
FYI - I got 3M clear Flexible Seam Sealer ($17) for 1/10 gal, but I am not convinced it is correct for the application. As it does have slight shrinkage. Other products state that they have no shrinkage and that is prolly what I need.
And just to beat this horse to death, please see related posting I made a while back. http://forums.corvetteforum.com/pain...to-repair.html
Thanks Gents.....
Here you can see the seam on mine after I have bonded the firewall back on to the birdcage with the fusor adhesive just starting to squeeze out some. There is also two rivets that go through the front side of the firewall kitty corner to that seam to help hold the firewall to the cage. In my opinion that particular seam is not likely to be the cause of to many leaks and would not concern me as mush as the other areas you indicate in your previous post. There are more leak prone seams along the firewall that I would be concerned about like the top of the firewall in your pics is a good candidate for a leak if not rusted and pulled away you can put some fresh seam sealer there to help.
ikwhite
I revisited the ’69 AIM to see if I could get a better grip on the components and how they are assembled. I found the outer hinge pillar on J44 and ultimately J58 and J59 have the pictures of the Plenum Side Panel and Sill Extensions I believe I am looking for. J-147 shows a good view as well, but between all of these pics, I could not find the specific instruction on whether to use adhesive, Plastisol Sealer or Seam Sealers in these areas.
Last, with my link to my previous post, there are 2 areas of concern – the wiper/cowl area and then the door jambs. Is the consensus to use Seam Sealer at both areas, or is adhesive indeed required in the wiper/cowl area?
I am ready to get after it tonight after work...
