I have a thread in the general section (71 Strip down) but I was looking at the engine and head numbers and I have a 1971 coupe that was originally a 350/270 hp car. The engine that came with the car has no vin # but the suffix code is V0803TRJ, and a casting number of 3970010, which I believe is a Flint, August 03, 1972 4 bolt main, with head numbers of 14022601 and 14022801 with code of B/07 and J/20 (14022601...1980-1986...267/305......1.84"/1.5" valves, 58cc chambers)and the same specs for the 14022801 head, just different dates. The car has a 4-speed, what can I do with this engine, the block seems to be a good block,and a Eldebrock Performer intake, but do I get new heads or rebuild these,(someone said these would make nice doorstops! LOL) I am looking for more perfomance, car has 3:36 gears.
Those heads will make a good door stop. Do not rebuild them. On the heads what is your budget. You can spend anywhere from 600 to 2000+ for heads and what kind of power are you looking to make with your motor.
Hi Jim
I changed my engine heads with Iron Eagle DRT-10121111 and change also to flat top piston and deferent *** to get ~375-400hp.
I send you PM
Avner
Before you plan further for TJR ... Suggest you also physically look & measure bores ... 350 or 307 ... steel or iron crank ... etc etc. It may've been rebuilt/reassembled with who knows what ... maybe sugar maybe shat.
I was looking at heads and other parts at Summitt Racing. They have some "World heads" that look good and this is on a recommendation from a friend who races, but as far as stud size diameter (3/8 or 7/16) and roller rocker ratio (1.5 or 1.6) and pushrods, its gets overwelming as far as the choices Any thoughts? I am looking for some horsepower gains, and I want to replace the heads in it now(as someone put it "doorstops") and this motor has an Eldebrock performer intake and carb on it now.
If it is a 307 start over. If it is a 350 4 bolt main, forged crank (truck motor) it is a great base.The heads you have are junk. Anything else will help power. Im an AFR guy.
