intake manifold, need help.
Old Feb 2, 2002 | 09:57 PM
JackCooper's Avatar
JackCooper
Default intake manifold, need help.
I've got my motor built except for putting on the intake manifold and
I've hit a bit of a snag.
I'm using sportsman II 64cc heads, and the stock intake manifold.
However, the intake manifold has some sort of metal tube portruding
through one of the holes and it is meant to go into the head. However,
it is too long for the new heads. My question is, what the heck is the stupid
thing and can I remove it so that I won't need to buy a new intake manifold?
Old Feb 2, 2002 | 10:07 PM
Ganey's Avatar
Ganey
Default Re: intake manifold, need help. (JackCooper)
If you are saying center of right (pass.) side of manifold, a loop, that is the choke tube for carb. If so, then yes, you could remove from top right of manifold or make shorter.
Old Feb 3, 2002 | 10:21 AM
dman535's Avatar
dman535
If you are using Sportman heads they usually have the exhaust crossover blocked off. The hot air choke system on the carb is not going to work properly. You might want to consider investing in a new intake/carb combo. Something like en edelbrock performer carb/intake setup will run you about $300 new. If you dont want to do that I would get a block off plate and convert the car to an electric choke. Edelbrock does sell a plate to do that here :
http://www.edelbrock.com/automotive/install2.html
Old Feb 3, 2002 | 11:00 AM
Paul L's Avatar
Paul L
Is this the tube? If yes I would take the advice of others. Remove it, block off the hole with the part from Edelbrock and install an electric choke.
To intake manifold, need help.
