Black wire from Thermal Limiter
Old Apr 29, 2009 | 11:17 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Default Black wire from Thermal Limiter
What does this black wire from the A/C Thermal Limiter attach to? (73 LS-4 with A/C).
http://s421.photobucket.com/albums/p...4-29-09004.jpg
Thanks!
Old Apr 29, 2009 | 11:41 PM
TimAT's Avatar
TimAT
The one with the boot? Superheat switch on the back end of the a/c compressor. If it's missing, don't worry. At least you won't have to stock up on the thermal limiters.
I thnk the same guy that came up with that system designed the gas-to-diesel Olds 350 conversion.
Old Apr 29, 2009 | 11:42 PM
72ragtop's Avatar
72ragtop
looks like the heat switch plug, which is on back of compressor . Assuming its the same as my 72 would go to a prong sticking out of back of compressor.
Old Apr 30, 2009 | 12:07 AM
73, Dark Blue 454
Yes the wire I'm holding with the female connector is connected to the thermal limiter.
Attaches to the back of the compressor?
Thanks!
Old Apr 30, 2009 | 09:24 AM
TimAT's Avatar
TimAT
If your compressor still has it installed, there's a single pin sensor held in the back of the comressor with a snap ring. If it's not there, I's tape that connector back into teh harness and be done.
In '72-'73 I was working for the rental car shop of a large Chevy dealer- I used to carry one of those limiters in my pocket. Customer would stop by, "My A/C is not cold!". Stick a new thermal limiter in and the compressor would start running. Easier than getting them another car.
To Black wire from Thermal Limiter
