Sending Unit Location for TH400?
Old Apr 30, 2009 | 04:13 PM
Fishndude's Avatar
Fishndude
Default Sending Unit Location for TH400?
1. Where would I install a temp sending unit in my TH400?
2. I have the trans out of my car and it could use a new oil pan gasket while I'm at it, can I roll the trans on its back do to this? The fluid is already drained but I want to make sure I wont be damaging anything by leaving it on its back for a day or so?
Thanks!!
Old Apr 30, 2009 | 06:50 PM
baxsom's Avatar
baxsom
can you T into where the fluid line comes from the radiator
Old Apr 30, 2009 | 07:29 PM
'75's Avatar
'75
While you have the pan off, you could weld a bung in for the sender and a drain plug too.
Old Apr 30, 2009 | 08:03 PM
Fishndude's Avatar
Fishndude
Do you know if they make a gasketed fitting that just requires drilling a hole in the pan instead? My pan is aluminum and I dont have a tig welder.. I suppose I could installl it in the output line of the trans but dont know where to find a NPT "T" fitting or a barbed T fitting.. Any links would be appreciated..
Old Apr 30, 2009 | 08:27 PM
'75's Avatar
'75
This might work depending on the thickness of your pan,
http://store.summitracing.com/partde...5&autoview=sku
Old Apr 30, 2009 | 08:32 PM
Fishndude's Avatar
Fishndude
Dang, I just spent the last hour looking through a Summit and Jegs catalog and couldnt find anything like that.. That looks perfect, thank you!!!!
To Sending Unit Location for TH400?
