Alignment - Converting inches to degrees
Old Apr 30, 2009 | 04:14 PM
redman76's Avatar
redman76
St. Jude Donor '09
Default Alignment - Converting inches to degrees
All the specs I have show Toe in inches, but my alignment shop gives me actuals in degrees . . . how do I convert inches to degrees so I can compare my results?
Old Apr 30, 2009 | 04:39 PM
Alan 71's Avatar
Alan 71
Hi R76,
The Chassis Service Manual has the alignment specifications for caster and camber in degrees only, since that's how they're set. The toe-in spec is in both degrees and inches.
Look in the back in the Specifications section.
Regards,
Alan
Old Apr 30, 2009 | 04:42 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Eighth grade geometry.
Old Apr 30, 2009 | 11:53 PM
redman76's Avatar
redman76
St. Jude Donor '09
Originally Posted by Alan 71
Hi R76,
Regards,
Alan
I've recently upgraded my suspension and I'm setting the specs for advanced street which isn't stock. I was hoping there might be a quick reference chart with a general conversion.
That is part of my problem, it's been 20 years since I did any calculus -- forget 8th grade. I need a quick refresher or the shortcut you guys are using.
To Alignment - Converting inches to degrees
