o2 Sensor Guru Needed
Old May 1, 2009 | 07:01 PM
Whiplash71's Avatar
Whiplash71
Default o2 Sensor Guru Needed
I'm looking for some feedback on o2 sensors for EFI.
I'm installing a ProFlo2 kit on my car. The o2 sensor is a 3 wire sensor provided with the kit. I've got some clearance issues with the sidepipes, the sensor, and the bottom of the frame.
I'm hoping to find a shorter sensor than the one that came with the kit.
My question is "are all 3 wire o2 sensors (with the same threads to screw into the bung) created electronically equal?" What I mean is if I find a shorter 3 wire sensor will it send the same signal to the computer as any other 3 wire sensor?
Thanks.
Whiplash
Old May 1, 2009 | 10:21 PM
mrvette's Avatar
mrvette
Thanks.
Whiplash
YES, unless it's the one intended for after a cat *** trophic converter....those MAY be different, I dunno....
but the two white wires go to the heat element, the black is the output, with the bolt being the typical ground....
Old May 2, 2009 | 09:24 AM
Whiplash71's Avatar
Whiplash71
And the black will send the same voltage back to the computer regardless of o2 Sensor manufacturer/application?
To o2 Sensor Guru Needed
