oil pump pickup help
Old Feb 3, 2002 | 07:45 PM
Turbo-Jet's Avatar
Turbo-Jet
Default oil pump pickup help
i have a problem with my new oil pump and pickup. i am trying to set the height, but in order to copy the old one, the pickup ends up at a funny angle, ie the pickup is not parallel to the pan bottom (or at lleast not parallel to the old pump). if the lowest point is 1/4" away, then it looks as if the high side will be about 1/2" away, maybe more.
is this ok? to be expected with a replacement pump (sealed power - federal mogul) and something to live with?
thanks.
-cam
[Modified by Turbo-Jet, 3:46 PM 2/3/2002]
Old Feb 4, 2002 | 04:33 AM
Turbo-Jet's Avatar
Turbo-Jet
Default Re: oil pump pickup help (Turbo-Jet)
ttt
[Modified by Turbo-Jet, 12:33 AM 2/4/2002]
Old Feb 4, 2002 | 06:52 AM
VettePaul's Avatar
VettePaul
I'm having the exact same trouble at the moment with mine. I've bought a high pressure/high volume oil pump and the whole thing is about 1/2 inch longer which means the pick-up tube is hitting the baffles in the sump. I'm having to cut away a little. :mad . Like you mention, mine too is at an angle. :confused: VettePaul.
Old Feb 4, 2002 | 10:47 AM
Tom454's Avatar
Tom454
Default Re: oil pump pickup help (VettePaul)
Pickups are not "all the same", just like small block water pumps and oil pans are not "all the same". You should be able to order the correct pickup if you have an OEM pan. If not, the pan manufacturer may have the correct pickup.
Here is an example, but not where you need to look...
http://www.melling.com/production1.htm
[Modified by Tom454, 10:02 AM 2/4/2002]
To oil pump pickup help
